Injection Pump Leaked Then Stopped
terrydtdi
Charleston S.C.
2000 MK4 TDI Jetta 5spd
About a week ago ,after driving 20-30 miles the IP leaked between the pump head ,and IP body ,from the bottom.
Tonight I decided to fire it back up (it's been a few days since the leak) ,idled for a while ,then drove around for 30 minutes , came back and NO LEAK :confused:
I guess the O-ring sealed back up , temporarly I'm sure .
PDJetta
Northern Virginia
There is a write-up on this list, with pictures, on how to replace that o-ring. Its a very tricky operation, but someone figured out how to do it without all of the high-pressure pump innards falling out when you do it.
--Nate
Naimanator
Davis, CA
Silver 2002 Golf GLS TDI
Dieselgeek.com sells a viton head o-ring replacement kit. It also comes with all of the instructions you need to do the job.
TonyJetta
Tucson, Az
'15 Jetta TDI SE / '06 Jetta TDI DSG Pkg0 / '96 Passat TDI
Here's the how-to for the IP reseal (Top, Middle, and pump head).
If you are doing anything other than the pump head and top seal, you WILL need VCDS (was vag-com).
Tony
Suharianu
Israel
00 GOLF tdi AHF auto ,07 Skoda BXE PD DSG
dont worry the leak will come back-same happened to my son golf 200k km's
started with lower leak then upper iq leak , head leaked also
i tried to avoid the head o ring - for a while it stopped leaking
but after a few days started to leak again so I took the pump out
put it head up in a vice and did the head o rings (there is
a smaller one around the center bolt)
