Old July 12th, 2019, 04:19   #31
eddieleephd
Fuel Economy: 38mix / 47@70-75
Originally Posted by Stephen417 View Post
When I went to look at the air mass specified vs actual... specified stayed at 850
I'm unfamiliar with your tune, therefore, I have no idea what it's written to. What does the actual do at the same time?
This can be logged and graphed just as boost is.
^^fuel temperature reading b should also be checked before starting the vehicle.^^
Really, when trying to trouble shoot, you should look at all pressures and temperatures before starting the car and after warm. It will tell you a lot.
Fuel temp and air temp should be the same when the car is cold. Fuel temp will increase slowly as the vehicle warms up. This is due to the return fuel warming it up.
Air mass temperature can go down when driving, usually nominal, and goes back up a bit when sitting.
If either temperature doesn't change, or neither are close at startup then the sensor that's the furthest from ambient at first will be wrong.
'02 1.8t Jetta Wagon Alh w/5spd swap, SB 21#SM DD, bew lift pump, 11mm IP, VNT17, Malone stage4 tune, Stealth pipe, BMW Cyclonic CCV filter, 2.5"cat back st. pipe,Vr6 brakes, 2" lift, Panzer, Bilstein HD, fill tube ectomy, soon to be Wuzetem p.520 PD_fuel_delivery TDI Search Plug release tool Howto terminal release tools VW/Audi
eddieleephd is offline   Reply With Quote
Old July 12th, 2019, 06:52   #32
Stephen417
When I get out of work Iíll make up a few logs. I appreciate the help.
Stephen417 is offline   Reply With Quote
boost issue weaverracing VW MKIII-A3/B4 TDIs 1 April 11th, 2014 13:06
HELP! 99.5 jetta alh boost problems, as well as unknown noise Alexanderp VW MKIV-A4 TDIs (VE and PD) 6 November 8th, 2011 12:28
Boost issue, please help an60an TDI 101 8 December 9th, 2010 23:58
Starter gone bad / unknown issue lilredjetdiwagon VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 10 October 17th, 2010 15:31
Boost issue Zacho TDI 101 12 July 11th, 2008 18:58
Page generated in 0.13646 seconds with 12 queries
[Output: 55.35 Kb. compressed to 51.30 Kb. by saving 4.05 Kb. (7.32%)]
