she_loves_the_D
EDIT. FIXED THE PROBLEM. IT WAS THE CRANK SENSOR.
(specifically the wires leading into it.)
Just for reference this is a 2005 mk4 bew tdi wagon 5sp auto GLS.
For the past few months ive been waiting for my car to throw a code with no luck.
Its to the point were if i leave it at idle its bound to stall. Especially if it is hot.
Typically it will surge a couple times before it actually stalls. Its kind of scary when im taking a left turn and all of a sudden have no power steering.
(one thing to note is that i tested my mpg recently and it was 35mpg at 90% freeway this is the lowest ive ever had in a tdi)
I have not done too much to test it. I am mainly starting this thread because out of the 10 or so threads i read about this same problem. Nobody posted a solution.
I had 2 ideas of what it could be and now after reading those threads i have 3.
First is easy. I had a bad crank position sensor before and i replaced it with one out of my friends bew that just so happened to get totaled within a couple days of mine going out.
The thing is, the one i replaced it with never had any problems and when mine was going out it threw a code every time it would stall.
I think that might be where i start.
The second possibility is the flap in the egr. One of the times it stalled I opened my hood and could hear something making a noise that sounded like a small motor glitching. could not tell exactly where it was coming from but it sounded like the egr. This is while the engine was not running but the key was in the on position.
My idea on this is that the flap inside is either getting stuck or just running haywire. If it closes it seems like it could cause a stall without throwing a code.
Now the third possibility is the fuel. It seems like more people suggest that it is the lift pump. the electric one in the tank. Apparently it will even run when the pump is not working as long as there is no air in the line. The first euro models didn't even have the pump.
But it will occasionally stall.
Also i haven't replaced the fuel filter. But i should either way.
Other than that i haven't noticed anything that would cause it to stall. Its been happening for over 6 months now.
I can hear the lift pump turn on for 2 seconds every time i turn the key to the on position.
So if anybody has any ideas on what it could be or thoughts on the noise i get that sounds like the egr. or why im only getting 35mpg that would be super helpful.
Hopefully i can post a solution this time.
