adamss24
Hi guys, just wanted to know if the above issue is fairly common on the 1.9tdi 105 Bhp BKC engine, just had one in the other day and after swapping 2 injectors as readings were of the chart- I decided to whip the head and found rod me 4 bent. The car had a small misfire which the engine ecu tried to compensate by throwing a bit more fuel to balance !
The car is in very good shape with only 140k km on the clock and it has never been abused- coolant level is fine and turbo has no play. The tune is also stock !!! Why on earth an rod would bend on a stock motor never pushed to its limits ?!!
