Letty jetty
I have taken my car to three shops and paid out the wazoo trying to figure this out maybe you can help.
My 2004 Jetta TDI (manual trans, 250k) will randomly stall at idle at a light or or slowing down to turn. It is very intermittent in that it only happens once or twice every couple days. It starts right back up after. It’s done this since around the same time as I had my alternator fuse replaced and the wire from the fuse to altinator and the wire drone the fuse to the fuse box inside the dash replaced.
Here is what I have had fixed/replaced in attempt to fix this:
Cam shaft sensor
Mass air flow sensor
All air intile hoses checked and replaced
Lift pump
Fuel filter
Fuel injection lines
I’m on speck for my timing belt so shouldn’t need a new one till 270k I think. Anyone else had this happen?
Cam shaft sensor
Lift pump
Fuel filter
