Old May 12th, 2019, 09:29   #1
Edward0712
Default Bad map sensor?
Replaced the turbo, intercooler, map sensor (different part # from amazon)
They said it was interchangeable
Egr valve, cleaned intake
It smokes grey at idle & at really bad at 2,500 rpm
Passed emissions 2 days ago
I think the map sensor is to high
Readings are at idle & new # / old# of map sensor
Any help appreciated
Sent from my SM-G950U using Tapatalk
Edward0712 is offline   Reply With Quote
Bad map sensor? Edward0712 General Automotive 7 May 12th, 2019 09:55
bad map sensor lenoble22 VW MKIV-A4 TDIs (VE and PD) 15 March 23rd, 2018 08:34
MAP 25 Sensor vs MAP 30 Sensor mhintlian TDI 101 0 May 28th, 2015 07:38
Bad MAP sensor? Nil VW MKIV-A4 TDIs (VE and PD) 0 March 5th, 2014 19:23
WTB: Bad MAP sensor for an ALH wwhalenc Private TDI Items for Sale/Wanted 1 January 19th, 2004 16:36
Page generated in 0.12103 seconds with 11 queries
[Output: 47.03 Kb. compressed to 44.35 Kb. by saving 2.68 Kb. (5.70%)]
