there a hole @ about 12 o'clock, where the notched lock is inserted and it arow aligns to mark on lock.?? the head lose if # 1 up on compersion, #4 should be down from firing. it a 5-speed manual.
hitting valves!BRM engine has tooling to lock the crank. You would have to remove the harmonic balancer to use the tool. For rough estimate where the crank is, there is a button on the crank sprocket that can be seen through the harmonic balancer. When that button is about 8 o'clock position, you are near enough to TDC.
Truthfully, what difference does it make? If you are removing the head, take it off! It will become very obvious where the pistons are at that time...
There is a tool set we loan that you need to retime the engine. With the right tools, properly inserted, it's hard to get it wrong.
Here is the bigger question. Why are you removing the head?
Otherwise, on the PD motor, there is no timing mark to be seen on the flywheel. It's there, but it's straight down and covered by the bell housing. It does not matter if it's auto or manual.
How do you know is #1 is @ compression stroke, if I knew this i wouldn't have a problem.#1 and #4 are at TDC together.
When #1 piston is at TDC of the compression stroke, #4 is at TDC ready for the intake stroke.
I have an inserted it and pin the head installed the belt and hid valves @about 12:30 and 8 o'clock. on older VW TDI on back of the engine on the bell housing on top there was o 1" hole to view flywheel and there was a mark on there for a TDI, is it still there. Please.BRM engine has tooling to lock the crank. You would have to remove the harmonic balancer to use the tool. For rough estimate where the crank is, there is a button on the crank sprocket that can be seen through the harmonic balancer. When that button is about 8 o'clock position, you are near enough to TDC.
Otherwise, on the PD motor, there is no timing mark to be seen on the flywheel. It's there, but it's straight down and covered by the bell housing. It does not matter if it's an auto or manual.
I installed pin on head & on crank I installed the crank lock, there a hole about 12, o'clock where it installed and fit in with ger below, installed belt, removed pin & lock, Tried to turn CW hit valve @ 12:30 then went CCW to about 8: o'clock and hit valve again. PLEASE explain.BRM engine has tooling to lock the crank. You would have to remove the harmonic balancer to use the tool. For rough estimate where the crank is, there is a button on the crank sprocket that can be seen through the harmonic balancer. When that button is about 8 o'clock position, you are near enough to TDC.
Thus is with the head off Please.The position of the camshaft determines this.
Compression cycle will have the #1 cylinder cam lobes at about 10 o'clock and 2 o'clock.
Are you sure you have a crank lock for a BRM and not a BEW engine? That would throw things out. Not even sure if would fit but, maybe.
There is no compression cycle without the head on.
