UncleSpence
I bought a 2012 Jetta TDI recently for a price that I couldn't refuse. $7k with just over 60k on the odometer (6speed manual). Was recently from Michigan on the buyback program. Only issue I've found thus far has been that the original owner took the spare tire and tool kit out before they turned it back into VW. Did find the lug key which was a nice bonus.
It's a bit of a nuisance because anytime you put something in the trunk, there's no support, so it sags and all my groceries and stuff fall in a pile and disform the trunk lining.
I'm assuming by the size of the hole it was a full-size spare. Is that correct? My Mk4 tdi has a full size spare. Is there a year range of jetta spare tires that will fit this? Or does the Mk6 vary from the Mk4 and Mk5?
If you happened to steal yours before the buyback I'm in the market for a tire and kit.
Thank you for your time and infinite wisdom All Knowing Ones.
