Jeff7
Hey guys, I'm looking for help with trouble shooting what seems to be an electrical problem my jetta has developed, it's a 2009 Jetta TDI 6 speed with about 210km. Recently the engine has started to turn off for no reason, and never consistently. I'll be driving down the road and the engine will just shut off like I turned the key off. Then after that it won't want to start again, turning the key off then on won't make it go through its start up procedure (dash lights come on, all dials go to max then back down, ect). The ignition seems to work, it knows when I put the key in, but basically the car just stays in accessory. Sitting around for a couple minutes and then suddenly it will decide to work and I can start it up no problem. This all happened on the highway, but that's the only place I drive it. It started on a 3 hr drive, about halfway it shut off. The it happened about 6 more times over the course of 30 minutes, just trying to get home. Then the last hour was fine. It was really slushy out so I chalked it up to a wet sensor and didn't drive it for about a month. I took it out today and it happened twice, only about 5 minutes into a drive (3rd start after going to a couple stores in town). I'm not getting any engine lights. I live 3hrs away from the nearest dealer, I know I could get it towed with roadside assistance, but I'd like to sort out myself if I can, I don't want to spend thousands getting a dealer to troubleshoot an intermittent problem. Thanks for any suggestions.
