earthtobase
i have an oil feed line fitting at top of turbo, i am torque-ing approaching 30lbs., and i notice a shave of metal coming out of side of fitting, about 7/16inch, coming out of hole in side of fitting. i have to shim with wood the 90deg. bend to prevent this from touching the exh.manifold, and thus the 90deg. bend entering the fitting is ever-so-slight canted. i have photos but cannot attach here. does any of this sound odd to anyone? can anyone confirm what the oil line fittings torque should be? i'll guess 15ft.lbs.
