Old April 24th, 2009, 19:13   #1111
A_Shifter
Originally Posted by alphaseinor
Have you moved the pin on the ECU yet?
fold all orphans over 180* and heat shrink.
One tip on your camera, is to use the macro lens mode (some cameras it's a flower icon, some it's a M)
Yes, the #19 pin has been moved to the formerly empty #66.
I'm still apprehensive that freakin YELLOW/BLUE wire is maybe not the right one...any way to double check that?
Problems with intermittent VAG-COM communications (Yes, it's the real deal from RossTech, - laptop probs most likely)
Cool, orphans taken care of.
I'll try the macro lens next time.
2003 Jetta TDI Wagon
A_Shifter is offline   Reply With Quote
Old April 24th, 2009, 20:49   #1112
alphaseinor
Continuity check the yellow blue with where you think it goes...
alphaseinor is offline   Reply With Quote
Old April 24th, 2009, 20:54   #1113
A_Shifter
It's the one that had continuity to pin #9 on the 175 socket but was supposed to be YELLOW/GREEN.
I'm done for the night. Alpha, you've been a huge help today.
Tomorrow morning; goin' down to the local exhaust dude for a straight pipe. :-D
Old April 27th, 2009, 18:31   #1114
jasonTDI
jasonTDI's Avatar
Fuel Economy: 13.7 c, 12-15 towing hwy. 17-19
I'll post up another thread that could be linked to this one with the complete 3rd revision we did of the electronics. All the questions asked are covered and it's real simple to follow. It take just a few hours to do the whole thing. I REALLY do recommend an electrical continuity tester. Harbor Freight Tools sells a nice one for $30.
I say another thread as this one is just ridiculously big and takes hours to sort through.
Jason, Service work available. www.jasonTDR.com
Give a hand,www.akitas.org
jasonTDI is offline   Reply With Quote
Old April 27th, 2009, 21:52   #1115
A_Shifter
The more versions the better! I'm working on one for my car as well. Looks like one should not assume colors and pin references apply to their model just because it's pre 99.5 or post-whatever.
Old April 27th, 2009, 21:59   #1116
TDICADDGUY
TDICADDGUY's Avatar
Fuel Economy: 42/46/51 with 5 speed - was 36/40/42 with 01M
Great idea Jason...the more the better. I am going to need to get rolling on mine very soon. Trans is slipping more, shifts are getting harder...the rubber band is getting stretchier.
2012 BMW X5 35D 2000 NB with 3 pedal mod, RC3, PP520's, Eurojet SMIC, SBC 3, 2.5" side exit straight pipe, 2" lift.
TDICADDGUY is offline   Reply With Quote
Old April 28th, 2009, 00:02   #1117
alphaseinor
The wiring seems to be the sticking point for most people... but it's actually quite simple, just the wire colors were changed to protect the engineers.
Old April 28th, 2009, 16:30   #1118
A_Shifter
I'll be looking for it since I think I've just about exhausted the possibilities on this end.
Old April 28th, 2009, 16:59   #1119
GdB
GdB's Avatar
Fuel Economy: Good?
What would help here is a good close up picture of each modified connector so that wire color does not confuse.
Any volunteers?
EV's: 2019 Hyundai Kona Electric 2012 Mitsubishi i-MiEV, 2016 e-Golf
2002 Golf TDI, ONCCV, cat2 filter, 14lb flywheel, 0.658, 5 speed swap HOWTO:
http://pics.tdiclub.com/data/500/GdB...D_VERSION2.doc
GdB is offline   Reply With Quote
Old April 28th, 2009, 17:55   #1120
alphaseinor
So what do you have working right now?
Old April 29th, 2009, 09:50   #1121
A_Shifter
Wire colors as well as some pin numbers...
The really important stuff- Starter interlock and Reverse lights - so everything but the CC. Great thing about that is that the Jet is once again my daily driver!
I (properly) eliminated that pesky YELLOW/BLUE wire so now there is only one wire (BLACK/GREEN) running +12V to the Black (CC Cancel) switch. Then I connected the RED/GREY wire (from pin #3) to the CC Cancel switch as well as under the cowl, to the RED/YELLOW one that now goes to pin #66 at the ECU.
Still no cruise and I think I've run out of possibilities from the 175 relay, except those that are dedicated to the new 53 relay.
Old April 29th, 2009, 11:45   #1122
alphaseinor
Basically, you need +12V going to pin 66
Old April 29th, 2009, 12:57   #1123
A_Shifter
Any volunteers?
Yup. When I get this figured out I promise to detail what my car's conversion entailed. With at least some pics.
Old April 29th, 2009, 13:54   #1124
A_Shifter
There is +12V going to pin 66 as long as the ignition is on and the clutch is out. Which I think is good.
I'll try to get my hands on that VAG COM again...meanwhile, any other ideas?
BTW: Is there anything I need to do with the VAG COM to make this work, or is it simply a troubleshooting tool?
Old April 29th, 2009, 14:43   #1125
alphaseinor
it's simply a troubleshooting tool in this case... if your cruise worked before, then it should work now.
the +12 should be there if the foot is off the pedal (which is clutch in).
Page generated in 0.19541 seconds with 10 queries
[Output: 134.82 Kb. compressed to 112.54 Kb. by saving 22.28 Kb. (16.53%)]
