Old July 10th, 2018, 04:27   #2581
babydoll
trying for the cruise, did the inside wiring, wiring on the ecu/tcu has me stumped
moved the #19 wire [black] to pin 66 car was sluggish got a maf code, moved it back, # 18 blue/ light blue [had continuity with yellow red wire ], moved it to pin #66, throttle wouldn't work scanner said no throttle pos. return , moved it back car runs well again, looking for more wiring possibilities
babydoll is offline   Reply With Quote
Old July 10th, 2018, 07:40   #2582
alphaseinor
yeah... if #19 doesn't have continuity to the TCU pin, then you are on the wrong pin.
Pin #66, when you are done, should have continuity to the bottom clutch pedal switch. if it doesn't then you did something wrong.
alphaseinor is offline   Reply With Quote
Old July 10th, 2018, 07:52   #2583
boertje
boertje's Avatar
Also the wire at pin 19 will not be black but yellow/red. Look on page 41 of the attached howto for a picture of the ecu plug with pin 19 and pin 66 locations. It is very easy to mis count the pins.
The yellow/red from the ecu goes to the tcu plug. Check it’s continuity. This wire you need to connect to the yellow/blue wire in the tcu plug and it is this same yellow/blue wire (from the pin 9 of the old 175 relay connector under the dash) you connect to the clutch pedal cruise switch and should, from this point, give you continuity back to the yellow/red wire that you moved from pin 19 to the empty slot of pin 66.
'01 and a 2nd '01 and a '03 NB TDI with 6 spd manual. '06 NB GLS TDI DSG.
All with Malone tuning of course.
Auto to 5/6 spd manual swap with wiring instructions for MKIV. Click here.
boertje is offline   Reply With Quote
Old July 10th, 2018, 12:48   #2584
babydoll
good news , I have cruise, no indicator light I guess it has one maybe a bulb.
the previous owner did say had it hooked up to a vag com so I guess they changed it from a auto to std with it,, don't have mine yet. pretty shallow history , thanks much guys [ was looking at connectors on ecu backwards I guess]
Old July 10th, 2018, 18:40   #2585
boertje
boertje's Avatar
Not sure on the Jetta, but on my 2 2001 bugs, they show no cruise light when engaged.
Old July 10th, 2018, 18:51   #2586
alphaseinor
I forgot which cars have cruise lights, but I'm pretty sure it's only automatics... maybe Marin can chime in...
Old July 10th, 2018, 18:54   #2587
Maxg1850n
My 2000 jetta auto didnt have cruise lights before I did the swap
Sent from my LGUS997 using Tapatalk
Maxg1850n is offline   Reply With Quote
Old July 11th, 2018, 17:44   #2588
DCELL
DCELL's Avatar
Fuel Economy: 44mpg ave
my 2001 golf (original 5spd) has never had a cruise light.
TDI service work available on a limited weekend basis. Timing belts, maintenance, etc. PM me with your needs!
When opportunity knocks, and I'm not home, opportunity waits.
DCELL is offline   Reply With Quote
Old July 11th, 2018, 17:54   #2589
babydoll
I wonder where you could connect to have a light while cruise is engaged put a optional light somewhere
Old July 11th, 2018, 18:16   #2590
bobbiemartin
My 2001 Golf (factory automatic) always had a cruise light. You could probably swap in a cluster with a cruise light. Keep in mind the cruise light is rather worthless from the factory. It comes on when the cruise switch is turned to on. The cruise light in some clusters can be modified to come on only when the cruise is engaged. The cluster currently my Golf is that way.
bobbiemartin is offline   Reply With Quote
Old August 25th, 2018, 17:59   #2591
Dhawk12
Just finished converting my 02 Golf to a 5 spd and loving it! This forum was really helpful.
I have a question though. I am noticing a lot more engine noise coming into the cabin and it seems to be coming from the centre console area and also telegraphing in through the shifter. Has anyone else had this issue? I was wondering if I didn't put the heat shield on exactly right or something. The only other thing I could see that might be causing it is that one of my coolant lines leftover from the automatic is touching one of the shift cables (the part that doesn't move) so that could be sending engine vibrations up the cable.
Dhawk12 is offline   Reply With Quote
Old August 27th, 2018, 18:50   #2592
DCELL
DCELL's Avatar
If you can feel the vibration, then I would check and recheck everything. Coolant lines shouldn't rattle- and they shouldn't be touching anything either- they will get holes worn through them. If you just think the noise is louder, you may just be hearing clutch noise- especially if you used a smf conversion or a Lightweight flywheel.
Old August 28th, 2018, 09:40   #2593
Dhawk12
It is not as much that I can feel the vibrations as much as I can hear them when you get close to the shifter. The coolant line that touches is one of the leftover trans cooler lines and it touches at the metal elbow at the back of the engine, so there is no way for me to move the coolant line out of the way as it is fixed (unless I bend the elbow) and the shift linkage is fixed by the bracket on the trans.
I have already anticipated the wear and have placed another piece of hose over the line as a protective jacket.
I did indeed install a SMF, but the noise I am hearing is quite distinctly engine noise coming from the centre console area.
EDIT: I discovered what the problem was. The donor car I got the shifter from was missing a piece of foam insulation that sits around the base of the shifter below the boot. Found one on another car, installed it and the noise went away.
Old December 12th, 2018, 16:45   #2594
SelbyTDi
Lightbulb word docs???
See several people talked about turning this forum in to a word doc or pdf was anyone successful in putting together a helpful one? would love to have a hard copy to look on while doing my conversion.
SelbyTDi is offline   Reply With Quote
Old December 12th, 2018, 16:58   #2595
SelbyTDi
Recently bought a 2005 golf tdi automatic to make into my daily driver (this is my first vw), car will not shift out of first gear and has check engine light. upon getting the car back to my garage i discovered tranny hadn't been serviced properly. i properly serviced the golf and was hoping this would help get the car driving while i gather parts needed for swap but no luck. it is a theory of mine that due to being in properly serviced that the car put itself in to safe mood to protect itself. is there anyway i can test this theory. i was aware of a transmission problem at time of purchase and plan on doing a swap but was hoping to get it driving for a month or two any advice or theories would be appreciated.
Page generated in 0.16481 seconds with 10 queries
[Output: 126.90 Kb. compressed to 105.91 Kb. by saving 20.99 Kb. (16.54%)]
