rrgrassi
I bought my car with Konig wheels on it. Noticed that those wheels were not hub centric. Finally after buying new tires last month, noticed the car still had a shimmy around 75 mph. Thought it was wheel balance. It was not and Discount tire suggested hub centering rings. Had themstalled. Big difference. But they only had the plastic rings and still had a slight shimmy. So I bought some aluminum rings. When I swapped them out, the plasic rings fit very loosely in the wheel. The metal ones had to be tapped in with a hammer and wooden block. Wow, no shimmy now, even at 95 mph. So, I do recommend getting the metal rings, if your after market wheels are not hub centric. Installing the wheels with the rings are a breeze now.
