Old May 11th, 2019, 09:06   #1
JELLOWSUBMARINE
JELLOWSUBMARINE's Avatar
Default Any Kenwood in Passat owners? intragration questions
I presently have the rsn 315 in my 2011 JSW. I want my old Kenwood sound quality back. My concern is... Will I loose the dash navigation turn by turn or will the Kenwood navigation head units intergrade those features with the right interface?
JELLOWSUBMARINE is offline   Reply With Quote
Old May 14th, 2019, 06:31   #2
740GLE
Did you ask in the JSW folder? I'm just guessing, but you may lose this feature.
The cluster of the JSW is slightly different than the Passat.
Old May 14th, 2019, 09:15   #3
abaron
I’m neither a JSW owner nor a Kenwood owner, however I’ve done quite a bit of research into this.
I own a 2015 Jetta and I’m planning to put a Kenwood (DDX996XR) into it (once they release it in Canada.
For your main question, it is possible to keep the turn by turn in the gauge cluster (probably). You’ll want to check out the Maestro RR by iDatalink. Their product allows you to retain those features and others from your car like steering wheel controls with select stereos.
You’ll also want to check out Enfig Car audio. They seem to have really nice dash kits plus the other adapters you’ll need (Like the amplified radio antenna, factory mic replacement, rear view camera adapter if needed). I’ve exchanged a number of emails with Christian and he’s been helpful and knowledgeable.
abaron is offline   Reply With Quote
Old May 14th, 2019, 10:22   #4
JELLOWSUBMARINE
Yes I posted there 1st with no response. I figure the Passat is close enough to compare generic feature retention.
Originally Posted by abaron View Post
Iím neither a JSW owner nor a Kenwood owner, however Iíve done quite a bit of research into this.
I own a 2015 Jetta and Iím planning to put a Kenwood (DDX996XR) into it (once they release it in Canada.
For your main question, it is possible to keep the turn by turn in the gauge cluster (probably). Youíll want to check out the Maestro RR by iDatalink. Their product allows you to retain those features and others from your car like steering wheel controls with select stereos.
Youíll also want to check out Enfig Car audio. They seem to have really nice dash kits plus the other adapters youíll need (Like the amplified radio antenna, factory mic replacement, rear view camera adapter if needed). Iíve exchanged a number of emails with Christian and heís been helpful and knowledgeable.
Thanks, let us know the ins and outs of the install. I hope your right I'll check with Maestro, Idatalink, so far all I've read is generic.
Any Kenwood in JSW owners? intragration questions JELLOWSUBMARINE VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 2 May 10th, 2019 07:57
Kenwood Stereo with Sirius for Passat or Jetta FS donniemac Private TDI Items for Sale/Wanted 9 November 1st, 2015 08:03
Kenwood DNX9980 or Kenwood DNX6190? thaghost Upgrades (non TDI Engine related) 3 September 6th, 2012 18:53
silly questions for owners vw4life VW B5 Passat TDIs 8 May 22nd, 2004 15:07
Wetterauer owners, I have some questions..... Peter Cheuk TDI Power Enhancements 6 May 4th, 1999 19:21
Page generated in 0.11020 seconds with 12 queries
[Output: 67.11 Kb. compressed to 60.26 Kb. by saving 6.85 Kb. (10.21%)]
