0die
there are conflcting indicators as to what my engine is...it has some AAZ parts but everything I've read says it can't be...
1996 B4 Passat, build date 3/96, "bonded title"...not neccessarily a rebuilt or salvage car but the old title/owner lost, car abandoned, mechanics lein or something...who knows...
VIN: WVWHG83A5TE184652
Head casting number 028103373N
Block casting number gone????? where I think it should be, above the oil filter, where I see other engine's block numbers....looks smooth except a "VW" stamp with two arrows circling the "VW" and the number "484"...is this a rebuilt/replacement block?
data plate of some type on the radiator support area says engine family "TVW1.9V6DFZE"
the timing belt tensioner is not the auto adjusting style, but older style with the 10mm (not 8mm) mounting stud for an AAZ engine or older IDI engines.
No throttle cable either, has intercooler, so it's a TDI...is this a "frankenstein" motor?
