ozymandias
First off, sorry if this is a common problem to have, but not common enough to where it pops up on simple search. Anyways..
So I start up the engine and release the E-brake and the 'brake' light doesn't go off, but just dims a bit. The brake doesn't seem at all engaged and i can drive normally, but also there seems to be no power in the center console. Just the environmental controls. No fan. No AC. No recirc.
This happens fairly often, EXCEPT if i turn the fan on before before releasing the e-brake. If i do that, everything is fine. This seems like a weird controller problem... kinda...
any ideas? weird, right?
