Old November 7th, 2019, 15:25   #1
Mozambiquer
Mozambiquer's Avatar
Default Zip tie mod how to?
I've been trying to find a how-to on the zip tie mod, I guess there used to be one on myturbodiesel, but it appears to be gone. I've used the search function both here and with regular old Google and I find a lot of people talking about it, but no how-to. My main question is how much vacuum to use. I kinda get the jist of the rest of how it works and all.
Sent from my KYOCERA-E6790 using Tapatalk
Mozambiquer is offline   Reply With Quote
Old November 9th, 2019, 06:58   #2
TDI73
TDI73's Avatar
https://web.archive.org/web/20170715...ptie-turbo.jpg
https://web.archive.org/web/20180606...ne-hesitation/
15 Golf TDI 6MT
Past:
06 Jetta TDI 5MT (BRM)
99 Jetta TDI MKIII 5MT(ALH)
97 Golf MKIII 5MT
TDI73 is offline   Reply With Quote
Old November 12th, 2019, 05:45   #3
dae06
dae06's Avatar
I've been using this mod for 4-5 years now. Every once in a while the zip tie breaks and I need to redo it.
Good luck, it's really not too tough once you do it.
2005.5 Jetta 1.9 TDI, Manual Transmission.
220,000 miles as of 03/12/2019; New Cam and TB as of 12/1/2014, New EGR valve and EGR cooler as of 3/29/2016.
dae06 is offline   Reply With Quote
Old November 12th, 2019, 10:36   #4
Mozambiquer
How much vacuum did you apply before installing the zip tie?
Old November 12th, 2019, 11:14   #5
dae06
dae06's Avatar
It was a trial and error process. When I finally got it tuned in, I ended up using 11" (I believe) zip ties and used 3 clicks on the zip tie.
For some reason I don't recall needing the vacuum pump (its been a while since I did this), I think the actuator is up until vacuum is applied and then lowers and this is when the zip tie limits the actuator from going too far.
After knowing the correct length of zip tie needed, I sized my zip tie, squeezed the zip tie to make it long and flat and pointed to push down and lassoed the actuator on the turbo from the engine compartment and hooked the other part of the zip tie over the vacuum port as shown in TDI73's first picture. (his zip tie mod was done with the turbo off, so he didn't need to form (squeeze) the zip tie to lasso the actuator)
I hope this makes sense. It still takes a little patience to get it hooked, but really isn't too tough.
I can definitely tell when the zip tie breaks, I lose power at take off and produce black smoke.
I hope this helps
Old November 12th, 2019, 12:54   #6
prsa01
FWIW - because I had read of people's zip-ties breaking and it was easier for me to get around the actuator I ended up using fairly heavy stiff wire. Got it the shape needed to loop around and back up.
I didn't have a vacuum pump available so just forced the actuator fully extended and then sized the wire to shorten its extension by ~ 3/8 inch. If that amount didn't do the trick I would have adjusted more.
Apparently I hit close enough. It ran great that way for the 2 years I owned it.
14 JSW 6mt pano & backup cam
96 B4v eCodes
prsa01 is offline   Reply With Quote
Zip-tie mod ziptie pics or help prsa01 VW MKV-A5 Golf/Jettas 18 April 13th, 2017 09:26
Passenger side strut install - Zip tie method Wankel7 VW MKIV-A4 TDIs (VE and PD) 7 October 10th, 2015 11:04
zip-tie mod questions... Spiked1Z VW MKV-A5 Golf/Jettas 10 May 25th, 2014 05:09
Zip, zip, hooray zip,zip hooray deeslman VW MKV-A5 Golf/Jettas 3 May 19th, 2014 04:26
WTB - DC/VA/MD - Drivers Side Tie Rod (or Tie Rod End) jwweatherman Private TDI Items for Sale/Wanted 0 August 9th, 2008 10:30
Page generated in 0.14130 seconds with 11 queries
[Output: 76.96 Kb. compressed to 67.34 Kb. by saving 9.61 Kb. (12.49%)]
