Old November 6th, 2019, 11:25   #1
favors_poppa
TDI(s): 2006 Jetta
Default Electrical Question
Not new to the group. Was around several years ago under the name jsw5620 but sold my TDI. Iíve read all of the no start threads. I have the opportunity to buy a 2006 Jetta with 256k miles on the odometer for $450. Car is pretty clean with only the sagging headliner. Car belonged to a guyís wife that traveled and was paid mileage. He bought a new one for her and this one developed the no start. Supposedly he changed the ignition switch. I hooked jumper cables to the car. Interior lights work, radio works, and keyless works. Nothing else. Turn the key and it does nothing. Did find a plug on ignition unhooked and plugged it in and made no difference. I tried the J329 relay but no luck. Appears to not be getting power to it. I can jump terminal 87 and 30 and dash comes alive. I donít have VagCom to read codes. Just curious if this sounds like a simple fix and worth $450. Dealer told the guy it was computer and wanted $1500 to replace everything so he sold it to a mechanic friend of mine for $450. Iím not sure if the switch was changed. The one laying in the floor has no vw markings on it. Anything I can easily try to see if this car has any life left instead of being a lawn ornament if I buy it? Thanks again and itís great to be back!
favors_poppa is offline   Reply With Quote
Old November 6th, 2019, 11:27   #2
favors_poppa
TDI(s): 2006 Jetta
Gear indicator was flashing when J329 was jumped. Not sure if that just because it’s been sitting or what.
Old November 6th, 2019, 11:42   #3
favors_poppa
TDI(s): 2006 Jetta
https://photos.app.goo.gl/k5tC9v87Ved8SAJw8
Old November 6th, 2019, 16:12   #4
favors_poppa
TDI(s): 2006 Jetta
Wrong forum?
Old November 6th, 2019, 18:47   #5
turbodieseldyke
turbodieseldyke's Avatar
TDI(s): 98 jetta
Fuel Economy: 50
Right forum.
I'd buy it.
turbodieseldyke is offline   Reply With Quote
Old November 7th, 2019, 06:13   #6
favors_poppa
TDI(s): 2006 Jetta
I guess Iíll take the gamble on it. Hopefully wonít be something major.
Old November 7th, 2019, 20:06   #7
favors_poppa
TDI(s): 2006 Jetta
https://photos.app.goo.gl/PQCdiNupX373YBP18
https://photos.app.goo.gl/KpMqansf2UvbtAn79
The first one was laying in the floor board, the second one I removed from the ignition. What is the part that goes bad and does the first one even go to this 2006 Jetta?
Old November 8th, 2019, 04:35   #8
favors_poppa
TDI(s): 2006 Jetta
Gonna throw an ignition switch at it and hope for the best
Old November 8th, 2019, 10:53   #9
favors_poppa
TDI(s): 2006 Jetta
No luck with the switch. It’s like a key isn’t even there. Checked all grounds and they are good. Only thing that will come on is the radio and interior lights. No dash lights, no chimes, nothing. Swapped J329 as well. ����*♂️����*♂️����*♂️
Old November 11th, 2019, 11:47   #10
favors_poppa
TDI(s): 2006 Jetta
Well resolved the issue. Someone pulled the SWCM fuse. Replaced it and now the key won’t come out of the ignition. Car cranks but but no start and no glowplug lights.
Old November 11th, 2019, 15:11   #11
favors_poppa
TDI(s): 2006 Jetta
Relay 100 engine bay fuse box doesn’t seem to be getting the ground signal to energize. Manually energize it and the fans will come on but still no start condition.
Old November 11th, 2019, 18:18   #12
favors_poppa
TDI(s): 2006 Jetta
No one has one this old anymore? Lol
Old November 11th, 2019, 21:00   #13
turbodieseldyke
TDI(s): 98 jetta
Fuel Economy: 50
More like, they haven't had the same problem that you're having, and have no way to help. I have no idea what Relay 100 is.
Old November 11th, 2019, 22:45   #14
favors_poppa
TDI(s): 2006 Jetta
https://photos.app.goo.gl/wLjJn3QafDxRmsJr9
Old November 12th, 2019, 14:25   #15
favors_poppa
TDI(s): 2006 Jetta
Issues resolved. Was missing fuses
Electrical Question duckey TDI 101 5 July 21st, 2012 06:07
Electrical Question Mr_Deezy VW MKIII-A3/B4 TDIs 1 October 15th, 2011 07:40
Electrical Question AIMENVIRO TDI 101 5 October 19th, 2006 17:15
Electrical question dubburke VW MKIII-A3/B4 TDIs 2 December 21st, 2004 12:31
Electrical question backhoeken VW MKIV-A4 TDIs (VE and PD) 2 May 2nd, 2004 08:16
Page generated in 0.18174 seconds with 11 queries
[Output: 115.07 Kb. compressed to 95.20 Kb. by saving 19.87 Kb. (17.27%)]
