Old October 28th, 2019, 23:30   #1
84Gliracer
Default Potentiometer Bracket
Does anyone know if you can still get a fabricated potentiometer bracket to fit a T4 TDI conversion
84Gliracer is offline   Reply With Quote
Old October 29th, 2019, 05:34   #2
G60ING
G60ING's Avatar
What pedal and engine are you trying to use?
G60ING is offline   Reply With Quote
Old October 29th, 2019, 14:28   #3
Josh_WA
Josh_WA's Avatar
If you are talking about the AHU/1z pot, I got a factory style bracket for my first van, from a fellow in the UK. If you go into the "vw t4 tdi conversion" group in facebook and ask, I think they will know the name of the guy. The brackets aren't OE, but could very well pass for it.
My second van, I built a bracket to bolt the passat pot bracket onto. Not a good picture but shows a little of the two brackets.
Josh_WA is offline   Reply With Quote
Old October 31st, 2019, 22:40   #4
84Gliracer
Sorry forgot some info
AHU have MK3 and B4 pedal
Old November 1st, 2019, 11:13   #5
CasaEd
I've just put a AWX PD engine in my B3 Passat and I used a bracket from a Rover 25 diesel, from Rimmer Bros in the UK, cheap enough I thought.
This one :-
https://rimmerbros.com/Item--i-GRID001117 Item number 7
CasaEd is offline   Reply With Quote
Old November 5th, 2019, 15:12   #6
Zed.
2.5 TDi potentiometer bracket - W7D0 721 531
try your local vw stealership for availability (nla in UK)
pedal is easy to adapt the origonal van item by welding the top of the tdi pedal to it, once the potentiometer is mounted it's easily mocked-up
I have a spare new potentiometer bracket in my workshop if you want some dimensions to fabricate your own?
Rich.
Zed. is offline   Reply With Quote
Accelerator potentiometer greenskeeper Private TDI Items for Sale/Wanted 2 December 16th, 2017 06:53
Need AHU potentiometer! sikmusicfreak8 Private TDI Items for Sale/Wanted 4 January 13th, 2015 20:40
WTB: B4 passat Tdi throttle potentiometer bracket GTiTDi Private TDI Items for Sale/Wanted 4 April 10th, 2013 18:52
FS: '98 Jetta TDI gas pedal with potentiometer, bracket, and mounting hardware. vwmikel Private TDI Items for Sale/Wanted 2 August 3rd, 2007 11:12
accelerator potentiometer pulido TDI Power Enhancements 0 December 30th, 2001 04:17
Đ 1996 - 2017, All Rights Reserved
Page generated in 0.16522 seconds with 11 queries
[Output: 74.47 Kb. compressed to 65.32 Kb. by saving 9.15 Kb. (12.28%)]
