Old October 12th, 2019, 10:59   #91
1998993C2S
1998993C2S's Avatar
Fuel Economy: 36 mpg..38, 44.5, 36, 37, 38
"Hey curious to see how long this car is going to last! Post up the following if you have over 200k miles!"
Mileage: 210k Miles
Avg MPG: 525-575miles to a tank on the hwy; 70-80+mph
How many Cams & lifters: 1 @ 155k Miles (VW/Castrol 5w-30 505.01, OCI-7Kmi or so, Pentosin 5w-40 505.01 used since approx. 18k mi)
How many Turbos: 1 @ 160k Miles (Old turbo was still good but VNT had a lot of play), EGR present
Performance Adders: Kerma-tune stg1, VW/Eibach lowering springs w/Koni FSD dampers, GTI 17" alloy's, Michelin Super Sports, Brake pads-Pagid Performance, Dynaudio DSP w/amplifier, and Dynaudio 10 speaker swap.
Any other major issues: A/C valve@compressor, HVAC vent motors, Seat memory/position switch x2, Rear brake caliper drag, Headliner replaced@year 12, Radiator fans x2, Glow plugs (4) at 190K mi, . . .
Cheers, MS
8/'06 Production .. Pkg2 .. Leather .. Navi .. Digital Sound w/Sirius XM .. DSG ..
... KERMA TUNE 1++ ... FSD dampers ... GTI alloy's 17"s ... Pilot Sport A/S 3 ... RoW OEM LED's ... R.Roll screen ... Dynaudio DSP active amplifier w/Dynaudio Spkr upgrade ... Under-the-radar aesthetic ... A long legged highway sleeper
1998993C2S is offline   Reply With Quote
Old October 14th, 2019, 21:38   #92
brianstrange
BRM, DSG 235K, Cam at 110K, DMF @ 80K Turbo Actuator at 180K (Used newer style, adapted to old Turbo.) Tires, Bearings and Brakes.
08 Ford Explorer, 06.5 Jetta TDI DSG PKG1, 94 Mustang GT Convert, 67 Mustang Convertible, 66 Bronco U140, 13 Audi A6 3.0T, 90 Mustang track car, 1977 GMC Royale Motorhome.
brianstrange is offline   Reply With Quote
Old October 22nd, 2019, 20:06   #93
x12gt
Fuel Economy: Pretty Rough
250k
Original Cam and Turbo, SMF Conversion
Malone stage 1 and EGR delete for 50k
No issues other than my flywheel rattling apart, a few glowplugs, EGR leak, and 1 front wheel bearing, oh and my turbo actuator is beginning to seize up.
Although it's never let me down mechanically, the Jetta is semi-retired, new daily is an 05 E320 CDI.
x12gt is offline   Reply With Quote
Old October 31st, 2019, 19:14   #94
GIDDY_UP_GO
Fuel Economy: 39mpg (But I drive 80mph alot!)
Just purchased a 2005 Jetta with the BRM and and auto tranny last night. Has 193k miles on it and just had the DSG service, timing belt/water pump and a new PD140 turbo installed all at 187k miles.
I think I got a pretty good deal on the car, the guy was originally wanting $5000 for it, but after a lot of negotiating, I got him down to $1500! (Basically the price of the turbo!)
2010 Jetta 160K mi (Fix Completed 12/17)
2013 Beetle Convertible 70K mi
2015 Jetta TDI 40K mi (Did the buyback on 2/17)
2015 Golf SportWagen 12K mi
THIS WILL MAKE YOU CRY!
GIDDY_UP_GO is offline   Reply With Quote
Old November 1st, 2019, 10:40   #95
relumalutan
relumalutan's Avatar
Damn, your negotiating skills are off the charts.
relumalutan is offline   Reply With Quote
Old November 1st, 2019, 20:25   #96
MPLSTDI
MPLSTDI's Avatar
TDI(s): 06 Jetta DSG
Fuel Economy: Max 54, 44 avg
212k
Original Cam, Turbo, Brakes, shocks.
GDE Hot tune for the last 60k, and EGR delete for 12k (EGR cooler failed)
DSG Flywheel at 124k , front wheel bearing at 130k, Driver door and injector harness around 100k, fourth set of tires. Alternator pulley around 180k, EGR coolant line around 140k.
Guessing less than 1k in repair costs with the flywheel being about 2/3 of it.
Doesn't use a drop of oil, and I would drive it across country today!
Member of the TDT for PD Mafia
2006 Jetta TDI DSG base 0 - heated seats Shadow Blue 212K ScangaugeII Hidden hitch GDE HOT/ECO Tune
MPLSTDI is offline   Reply With Quote
Old November 4th, 2019, 11:33   #97
Texas_sky
Fuel Economy: unknown at the time, waiting for engine swap
216k Silver Package 2, Replaced Cam, Flywheel, Egr Cooler @ 185k. Most likely will need clutch packs or trans and turbo, just changed oil. Whole front end needs attention, struts, control arms, ball joints, tie rods, etc. Doing front brakes soon. DSG due at 225k. Car was hit twice, once driver door and rear ended, I fixed both for less then $500 for new rear bumper, trunk lid and door panel including body shop pulling out the rear end. Headlights are like new. Would like to see this car go at least 300k+ before scraped. I have another one that is in better shape with only 143k that I drive daily. Brother is going to take this one over. Have too much in it to sell. Best to just keep it rolling.
Texas_sky is offline   Reply With Quote
Old November 5th, 2019, 06:22   #98
W7628
W7628's Avatar
2006 BRM w/232k, P2 w/Nav, Rear Sunshade, DSG. Just picked it up in August to replace my 2004 BEW that was sideswiped by a box truck and totaled. Nice ride so far; car has the 17" wheels so the ride is a bit stiffer than the 15" wheels on the BEW. Car was dealer maintained until 225k, then a guy bought it and did timing belt and water pump, kept it for 2k miles, and decided he didn't like it because of the 'hissing noise' he was told was 'normal for these cars'. So I just replaced the EGR cooler and coolant hoses; I blocked the cooler at halfway open and disconnected the vacuum line to it, so I'm hoping for a long cooler life since the bushing won't be seeing constant use. Also did zip-tie mod as that common boost issue presented itself as soon as I replaced the EGR cooler and closed up the exhaust system. For the moment, the car is running great and MPG is back to 42-44 where it was before boost problem surfaced. A 600+ mile tank is no problem. No signs of DMF failure yet; that will be next big-ticket item, and I'll do a DSG service at 250k. Hoping for a trouble-free run to 300k as I need this car for my 120 mile round trip commute.
Tom
2006 Jetta TDI P2
2004 Jetta TDI GLS wrecked 8/19
2000 Jetta TDI GLS sold ('ol Rusty)
W7628 is offline   Reply With Quote
Old November 6th, 2019, 20:40   #99
Mozambiquer
Mozambiquer's Avatar
Mine just passed 266k miles. Runs and drives, though not perfect. Camshaft and lifters replaced at 235k, as well as timing belt. EGR was deleted and has a stage 2 malone tune. It's now what I call a greyscale Harlequin because of hitting a deer and being t-boned.
Sent from my KYOCERA-E6790 using Tapatalk
Mozambiquer is offline   Reply With Quote
Old November 7th, 2019, 10:57   #100
Captainfh
New to the Forum, love the enthusiasm!
I have an 06 Jetta @ 232K miles with normal maintenance. Of course at this point in its life "normal" includes Brakes, Front wheel bearings & timing belts etc...Unfortunately, I will undertake the dreaded cam replacement this weekend-seems pretty straight forward for a gearhead such as I am. I do have a question to pose to all the like minded individuals that hang out here. When removing the valve cover last weekend i noticed that the previous owner has installed bailing wire on the VNT actuator on the turbo?!? To what end I wonder?
Let me back track to what led me to this discovery- After an extended lay up (6 months I work out of state) I noticed it seemed very loud compared to my wife's 03 ALH wagon. After checking all the normal things the car seemed to drive fine just like it has for the last 40k since I have owned it. Then bang it threw a P101 engine code- and and emissions Workshop warning -after probably not enough research I zeroed in on the Maf and replaced it. This was fine for about a week then the car did it again, in addition to losing all boost from the turbo. this time throwing a P101 and well as a P299 underboost code. So more reading and more listening and looking under the hood. I ran across the cam shaft issue online so off came the valve cover and it was pretty darn obvious what was going on in there (in addition to the Lub Lub sound coming out of the airbox) the # 3 and 4 exhaust lobes were badly worn. I am a firm believer that when it comes to mechanical things one should solve one problem at a time, but I am not naive enough to think that I am only dealing with one problem in this instance. So the camshaft first then to look good and hard at the turbo and that goofy bailing wire...
Thanks for letting me vent, any constructive input/help or like stories would greatly appreciated. These forums can be a really great resource
Cheers!
Ken
Captainfh is offline   Reply With Quote
06 brm jetta. High mileage. 38326. Middle tn ondwater TDI Cars for Sale/Wanted 3 August 26th, 2014 03:25
06 Jetta BRM high altitude issues kdawg89 VW MKV-A5 Golf/Jettas 1 April 23rd, 2014 18:18
New TDI owner. 06 Jetta (auto) high mileage Created VW MKV-A5 Golf/Jettas 5 April 3rd, 2013 06:48
Buy a high mileage 06 jetta? vwcruisn VW MKV-A5 Golf/Jettas 18 August 28th, 2010 15:20
Popular High Mileage contest - Under 200K need not apply ICNTDRV TDI 101 20 August 8th, 2006 22:13
Page generated in 0.15763 seconds with 11 queries
[Output: 104.44 Kb. compressed to 89.47 Kb. by saving 14.97 Kb. (14.33%)]
