Old March 5th, 2013, 19:56   #1
crdouger
crdouger's Avatar
Default Side mirror blinker bulb replacement
Anybody know how to get the lens off my 06 driver side door mirror so I can replace the burned out light bulb. I've gently pried on it with a screwdriver, but I'm afraid I'm going to crack it. Any help or pictures would be appreciated!
crdouger is offline   Reply With Quote
Old March 5th, 2013, 20:09   #2
nord
That "bulb" is actually a series of LED's. They aren't likely to burn out. More likely is a broken wire in the harness where it enters the door from the car.
nord is offline   Reply With Quote
Old March 6th, 2013, 07:44   #3
redbrick1
TDI(s): 2009 JSW TDI
The led's do go bad; my did at about 30K miles. I think moisture gets in and damages it. Anyway, an easy repair, see here: http://www.myturbodiesel.com/1000q/a...ment-jetta.htm
I bought the replacement part at the dealer (most conveinent), IIRC about $45 or 50 bucks. Good luck.
'09 JSW, Black/Black,DSG,Pano, stubby antenna
redbrick1 is offline   Reply With Quote
Old March 6th, 2013, 08:27   #4
1854sailor
Resident Curmudgeon
1854sailor's Avatar
Just had to repair my passenger side mirror because someone whacked it in a parking lot.
The part number is 1K0 949 101.
-George Bernard Shaw
Old December 3rd, 2013, 08:42   #5
CosmicMiami
Fuel Economy: 37.7 mix of city and highway
I'm having a similar issue on my driver side mirror on a 2010 Jetta TDI. It was blinking rapidly and intermittently for awhile and now has just a couple "bulb" working. The link is a little confusing. Must I remove the mirror to access the light housing?
CosmicMiami is offline   Reply With Quote
Old December 3rd, 2013, 10:20   #6
goosegunner
The glass comes out, then the housing. At that point you have access to the screws to take the inner black plastic off to get access to remove the light.
Its about a 10 minute job.
gg
goosegunner is offline   Reply With Quote
Old October 28th, 2019, 14:28   #7
srlbotanical
srlbotanical's Avatar
This is an old thread, but it comes up when you search.
Here is a good video on how to replace these.
https://www.youtube.com/watch?v=Nd1C9jkP1gI
srlbotanical is offline   Reply With Quote
Old November 9th, 2019, 07:09   #8
TDI73
TDI73's Avatar
link for the missing myturbodiesel wiki
https://web.archive.org/web/20180224...irror-removal/
15 Golf TDI 6MT
Past:
06 Jetta TDI 5MT (BRM)
99 Jetta TDI MKIII 5MT(ALH)
97 Golf MKIII 5MT
TDI73 is offline   Reply With Quote
Vanity light (above visor mirror) / removal and bulb replacement / How-To l_c VW MKIV-A4 TDIs (VE and PD) 16 May 15th, 2015 10:55
06 side mirror blinker bulb replacement crdouger VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 0 March 5th, 2013 16:24
Side Marker Bulb Replacement Jetta A4 iwish_iknew TDI 101 3 April 4th, 2005 09:03
Drivers side headlight bulb replacement wows! hlrd19 VW MKIV-A4 TDIs (VE and PD) 5 January 26th, 2005 23:45
Front Side Light Bulb Replacement Autopilot VW MKIV-A4 TDIs (VE and PD) 4 October 28th, 2001 20:41
Page generated in 0.15829 seconds with 11 queries
[Output: 85.08 Kb. compressed to 73.30 Kb. by saving 11.78 Kb. (13.84%)]
