Old April 29th, 2019, 18:17   #16
AKA John Smith
TDI(s): Toyota TDI
Originally Posted by jimbote View Post
you are correct leaving the exciter wire off most likely did not cause the failure..... and your jeep already has an alt light that will suffice....I used the stock toyota lamp and all is well....
My Toyota has a 3 wire harness and my TDI (alh) alternator has 2 wires. How’d you wire yours up?
Thanks!
AKA John Smith is offline   Reply With Quote
Old May 15th, 2019, 14:18   #17
Eric b fishing
TDI(s): 02jetta
Default 5 speed swap wiring
Hello
I’ve finished my swap an wiring. I have two problems . #1 my reverse lights stay on , is the switch on the transmission normally open ? # 2 my alternator just took a crap. When I key on I get power to both side of the two prong plug on the alternator , should I only have power to the “curved side of the plug prong “ or both sides ? If I have key on an remove the large plug to the computer then I just have power to the curves side of the plug to the alternator. Any help would be appreciated.
Eric b fishing is offline   Reply With Quote
Old May 16th, 2019, 08:04   #18
[486]
TDI(s): 02 golf ALH
Originally Posted by Eric b fishing View Post
Hello
on an 02 motor the two small wires to the alt are field and lamp
the light on the dash (also used to excite the alt) and a wire from the field coil to tell the ecu what percent load the alternator is loaded down (to switch on or off the coolant glow plugs, nothing more)
field ends up with some power when keyed on, but nowhere near full 12v as the lamp wire will not supply that much current to the regulator, talking maybe a couple tenths of a volt
lamp should be essentially grounded, key on not running, and the light in the dash illuminated
[486] is online now   Reply With Quote
Old May 16th, 2019, 14:46   #19
CasaEd
Can you see the color of the wires in the plug ? 1 is normally blue, that is the warning light wire, the other wire is usually brown/red, that wire go's to the ECU.
CasaEd is offline   Reply With Quote
Old May 16th, 2019, 22:31   #20
jimbote
jimbote's Avatar
iirc, there's a yellow wire from the toyota's cluster (charge lamp) that goes to the blue wire of the vw alternator, that's all i have to charge aside from the large wire... my alternator light works as required
jimbote is online now   Reply With Quote
Old November 7th, 2019, 06:47   #21
AKA John Smith
TDI(s): Toyota TDI
So, in a toyota swap, the field wire will be left alone?
I assume you just "dead-head" or unpin the field wire? What are the other two wires in the toyota harness used for?
Old November 7th, 2019, 07:31   #22
[486]
TDI(s): 02 golf ALH
yes
the ECU doesn't need it unless you're running the coolant-heating glow plugs
A/C Compressor and Alternator wiring mix-up? Slowrvr VW MKIV-A4 TDIs (VE and PD) 7 October 17th, 2011 14:59
alternator wiring skicat TDI 101 8 February 12th, 2011 09:34
Clutched alternator onto 1Z, Wiring? ryanp TDI Conversions 5 October 28th, 2009 12:18
New clutched alternator onto 1Z, Wiring? ryanp TDI 101 3 October 26th, 2009 08:17
B4 TDI, Alternator wiring DubbedDiesel VW MKIII-A3/B4 TDIs 4 November 26th, 2006 10:25
Page generated in 0.14617 seconds with 11 queries
[Output: 84.65 Kb. compressed to 74.12 Kb. by saving 10.53 Kb. (12.44%)]
