As mrchill stated, what's your goal, but also what's your budget? That is going to be where you want to start making your plan. If you're looking for a daily driver that still has plenty of torque around 2k rpm, just do the cr170 with an aggressive tune. I have seen a few folks on the VW TDI owners group on Facebook making mention of a hybrid cr170 and a JR Auto tune with some nice results.
I went with a Mercedes gtb2060vklr. I decided on this over a 2260 as I didn't want to go too nuts as the car is my daily, plus I wanted something different. I will be very honest though, I had to re-learn the best rpm's to shift, and there is no low-end torque like the stock turbo. It only starts building boost around 2200 RPM. So no more granny shifting at 2k. But run it to 3k or higher and she hauls. Mine is also watercooled, so that opens up another debate/decision of the vklr's need water cooling or not.
There is a fairly large cost difference. And you'll run into that cost difference with almost all the gtb setups you explore unless you can find a good price on something used. But also factor in the supporting mods to your cost as well
As another mentioned, fueling will be your next "issue", so I hope you have plans for a cp3 hpfp. Also depending on how big you go the stock injectors will be maxed and there's not anything proven as an option for larger injectors. I know Les mentioned he was testing some that were bigger but don't know how things turned out.
