Has anyone measured the distortion of an 058 block when under the use of a torque plate?
I know the impacts .003" can have on a big block chevy with regards to blowby near TDC... BTDT
I had my block bored under the promise of using a torque plate. I showed up early and the engine machinist was finish honing the block and the torque plate was 10 ft. away. It was dry and I am even having serious doubts as to whether or not he even used it during the cutting process... which is less important to the honing. I asked about it and he said he used it...
Not to mention... not one piston was marked as to which hole it went into...
This was a big bore to BHW's to clean up a cylinder... I am seriously considering taking it to another machine shop on Monday to verify clearances because the one gauge I don't own is a bore gauge...
Needless to say I am really irked over this...
