Festa
Hi lads I have a dilemma as to which way to go so would thought I would put it up here.
Story is I have had from new an 06 2.5 174 5 pot t5 panel van which is used as a works van but I started modifying in 2010 when the engine hydro locked on the diesel that leaked into the sump from the tandum pump.
In 2011 the core plug popped out the head and the engine dropped number 5 exhaust seating and stopped the valve from seating correctly so you can guess the rest. Cylinder bore was re- sleaved and rebuild with a bit of balancing here and there so a steady increase in power every time. It currently is over 280bhp without the LPG and just on 300bhp with it on the torque is a bit more than vw intended at over 600nm but it makes me want to go to work
Number 5 is suffering from lower compression due to the wrong piston rings being fitted at the time of the rebuild in 2010 and has worn the sleave to the point now where it needs a new lining. Now...
The purest in me is saying to keep what it came with and do a bit more but there appears not to be the tuning potential on the 5 pot pd as the rest of the engines in the vw range.
The engine itself was only produced from late 2003-2009 in the UK so a short production run and was only fitted in the t5 and the touareg. Probably down to emissions
My idea here is to strip out the engine and get rid of the plasma coating it came with in the other 4 cylinders and re- sleaved all 5. What I'm trying to find is another piston that is over sized to be a suitable donor and machine the sleaved to suit.
Possibly low the compression to get in more air for the bigger bang and port out the head to flow more air.
Fit larger nozzles to what I have at the moment or change out to the v10 touareg or phatton 560cc injectors with a larger nozzle.
The other option is to change from a transverse to an inline v6 diesel common rail and fit the manual gearbox with the Quattro running gear, a lot of work but could be fun
It's a works van and the load in the back does vary so having more power on the front wheels trying to find traction is possibly a problem, the same as rear wheel drive and being unloaded
I have a donor van that I can use as a mock up before it's transferred into the current vehicle I have so to reduce down time before the current engine expires
With the v6 I can see a few problems...ECU from the donar talking to the vehicle, gear selector cables and drive shaft lengths.
Also trying to reduce the nose weight by pushing the engine back as far as possible without interfering with the front drive shaft angles to reduce under steer.
I could be looking at another potential 150 bhp and another 200-300 NM of torque from the v6 but it's time and ££££
I need a bit of guidance and sensible answers
