noelchenier
Hi everyone
I have a 2006 Jetta TDI with 425,000kms
Recently I started having intermittent issues with acceleration driving my TDI.
It tends to happen more when I am accelerating up inclines, but I have noticed it on flat.
Put the pedal to the floor, no acceleration at all.
The gear drops to 4/5, speed drops.
Pull over, shut the car off.
Start it up, acceleration is back to normal.
Using an ODB scanner, it shows P0404, and occasionally P2413.
Took it to the local VW shop (not the dealership) and of course when they take it out, works flawlessly and there is no obvious cause.
Thankfully these guys aren't the type to start replacing expensive parts for the hell of it, but I use this car to commute 3 hours a day and need to get back and forth safely.
So I'd like to try to fix this, or decided if it's time to buy a new car.
The only work that has been done recently was the fuel filter being changed about 5,000kms ago.
Any suggestions?
Also, I'm a not a mechanic, so if I'm not giving enough info, please let me know.
Noel
Any suggestions?
Noel
