aja8888
2005.5 MKV Jetta, DSG, 125,000 miles. The lights worked last time i checked.
I did search and saw some threads on a possible bad harness, but everything else works except those plate lights. No power to them and I don't have a fuse diagram. But I kind of doubt that one fuse would be the culprit. But is there a lonely fuse for this circuit? Anybody have this situation? The car was outfitted with LED tails by the original owner so I know someone was messing with things.
Here is my VCDS scan (edited short):
Thursday,01,August,2013,19:37:03:25200
VCDS Version: Release 11.11.6
Data version: 20121223
VIN: 3VWST71K85M641228 Mileage: 201200km/125019miles
01-Engine -- Status: OK 0000
15-Airbags -- Status: OK 0000
1C-Position Sensing -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
7D-Aux. Heat -- Status: OK 0000
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 1K0 937 049 C HW: 1K0 937 049 C*
Component: Bordnetz-SG H34 0803
Revision: 00H34000 Serial number: 00000000061389
Coding: E4018A1641041800000000000F000000002151005C
Shop #: WSC 00000 000 00000
VCID: 2F43F286BE7F3C60891
Subsystem 1 - Part No: 1K1 955 119 B Labels: 1KX-955-119.CLB
Component: Wischer VW350 012 0401
Coding: 00065493
Shop #: WSC 00000
Subsystem 2 - Part No: 1K0 955 559 M Labels: 1K0-955-559-AF.CLB
Component: RegenLichtSens 005 0605
Coding: 00479269
Shop #: WSC 00000
1 Faults Found:
01504 - Bulb for License-Plate Light (X)
012 - Electrical Fault in Circuit
New bulbs are in and voltmeter to terminals show nothing. I have not pulled the cover off the inside of the trunk to chase wires yet. That's tomorrow after work.
Coding: 00065493
Shop #: WSC 00000
Coding: 00479269
Shop #: WSC 00000
1 Faults Found:
