Ryan_B
Hello all. My wifes car sat for a couple of weeks and she went out to drive it. It had no brakes. Thinking there was a problem with the MC, I replaced it. There was no fluid leaking into the booster area from the old one. After it was replaced she would get periodic times I had to add fluid cause the warning light came on. I disconnected and plugged the hose going to the upper back area but that made no change (what does this do anyhow?). Still losing fluid. I've checked around the Master Cyl and can see or find no leakage. I've checked around each of the disk brakes and also cannot find any leakage. If I bleed the brakes it has no bleed down or quishyness. I just cant find where the fluid is going. Idea's ? If the car is driven regularly the issue occurs every couple of weeks. but if it sits for more than a few days it happens very quickly (low fluid level). It's a real head scratcher for me.
