Old August 10th, 2007, 03:54   #1
G60ING
G60ING's Avatar
Default Engine Wiring Harness Question...Swap a Mk3 Harness for a B4?
I'm doing a TDI swap into a corrado using a Mk3 as a donor. But the wiring harness of the Passat fits the holes on the corrado's firewall a little better then the Mk3 harness. I spent a couple hours last night comparing the wiring diagrams for both bentley manuals and at first glance it looks like there should not be any problems with using a B4 1Z harness on a 1998 AHU Mk3.
Does this sound reasonable or am I the only oddball to venture down this road?
G60ING is offline   Reply With Quote
Old August 10th, 2007, 04:34   #2
Lug_Nut
Pre-Forum Veteran Member
Lug_Nut's Avatar
Whose ECU will you use? The B4's, or the A3's?
The 1996 B4 harness has provisions for the temp sensors at the cat and the pump wiring for the supplemental 5th injector.
These components were deleted from the 1997 model year so a 97 B4 harness should be compatible with the A3 ECU.
The sensors and their feedback through a 96 B4 harness to a 96 B4 ECU can be mimiced easily enough if the equipment isn't present, but it's one step to consider.
A 96 B4harness with the 97 B4 ECU, or an A3 ECU may be problematic if the harnesses are differently wired at the ECU because of these component deletions. It's uncharted territory to me.
Svante Arrhenius 1896
Old August 10th, 2007, 09:18   #3
G60ING
G60ING's Avatar
Does anybody know what pins on the ECU plug these emission parts are?
Page generated in 0.13992 seconds with 10 queries
[Output: 54.18 Kb. compressed to 48.86 Kb. by saving 5.32 Kb. (9.81%)]
