BioJoe
9/10/16 - 6th Annual Midlands/Green Energy Biofuel Summer GTG
OK Boys and Girls, Wrench Turners and On lookers, and TDI enthusiasts alike,
It is time for the 6th Annual Midlands Biofuels/Green Energy Biofuels GTG - September 10th.
Event will be Downtown Winnsboro, SC.
Location: Main Street Winnsboro, SC, beside Shell Gas Station and across the street from the Dodge Dealership.
Plant Address: 310 South Congress Street, Winnsboro, SC 29180
BIOJOE says:
8am till 5 PM
Food : TBD lunch item. Please bring any complimentary sides you'd like to share.
Biodiesel $2 per gallon on the b100 available with Biocide and antioxidant added. We call it the "BioPro" blend.
I'll spray Side lot for mosquitoes again this year.
There's a car lift inside the plant and plenty of room to work on cars on the concrete as well as in the shaded grass areas beside the plant.
Pop Up Tents and bag chairs are always welcome.
A/C inside and 2 bath rooms with changing room.
Gas station next door if you need extra drinks and snacks.
I will be giving several tours during the day. We have retooled the entire Biodiesel plant to add methanol recovery and have eliminated water washing to purify fuel and now purify via Centrifuge! We have added over 20,000 gallons of process tanks, covered work area and filtration, as well as a new waste oil boiler that uses anything from motor oil to veggie oil to heat the plant.
Please DO NOT bring any used motor oil!! COOKING OIL ONLY!!! $.50 off per gallon donated. We've had people bring 100's of gallons in the past and paid for others discounts per gallon on biodiesel.
BYOFC - Bring Your Own Fuel Cans or I'll have some used totes and car boys you can use for temporary transport for free if you want.
Email biojoe@midlandsBiofuels.com or call 803-718-4727 if u need anything."
BIOJOE says:
8am till 5 PM
