Diesel Life
Problem : no power, will not rev past 2500rpm, won't go over 20mph!
What I've tried: new MAF, MAP has normal output (0- 14psi), new turbo and vnt actuator, tested N75 valve, cleaned out intake manifold, pump and injectors work (spray into open air), fuel supply appears to be unrestricted (vacum gauge, inline between filter and pump, reads 8).
Comment: took it for a ride, timing advance stays at 1. My friends TDI goes all the way up to 15 while under boost. Could be a problem with the pump???, computer??? Sorry, I do not have VCDS, I have a code reader that does live data (hey, it's something!)
Any suggestions???
Any suggestions???
