Hi,
I've just had the head on my 98 Passat (AFN engine) resurfaced to remove a burn crater where the head gasket had failed. The machine shop said they removed 1/10mm. Now they (and the mechanic) want to use a 3 notch gasket to compensate for this. The gasket that was on was a 2 notch. No-one has yet gone to the effort of measuring the piston projection.
Just to be clear. Nothing has been done to the valves or seats (they will be ground with paste on reassembly) so theoretically the valves now protrude 0,1mm further out from the head surface.
I already have a 2 notch gasket which I bought, hoping the head would not need any work. Can and should I use this? Will I really notice any difference in performance / cold start / economy if I use the 3 notch gasket?
Looking at the gasket criteria:
If my piston projection is in the upper range for the 2 notch gasket it could be 1.10mm. The gasket is 1.53mm, leaving a gap of at least 0,42mm between the piston crown and the head.
How deep are the valve depressions in the piston? I read somewhere in here that Frank's TDIs developed some sort of rule of thumb that valve protrusion should not exceed 0.03" (0.762mm).
How fine can these clearances be? If my valves were already protruding 0.76mm (assuming this rule of thumb is developed to maintain factory clearance and that my valves are at the worst end of factory protrusion) they may now protrude 0.86mm after the skim. The necessary depth of the valve depressions in the pistons should then be about 0.6mm. (Well, that's a tiny clearance I think. Possibly problematic )
I also read in here that some guy measured these depression to 1mm deep. If that's the case I should be fine to use the 2 notch gasket. Or??
It's a little difficult for me to measure these things as the head is still with the machine shop and my only car is in bits at the mechanic's place. I get around by bus for now...
Any recommendations? The above values should be worst case numbers and so I assume the real case might be better. Is the 0.1mm skim really enough to justify the change to 3 notch gasket? Are the mechanics just staying firmly on the safe side?
