Old April 20th, 2016, 09:13   #16
Bambaataa
Fuel Economy: 47Mpg
Do you have a public listing of your price(s) somewhere?
Bambaataa is offline   Reply With Quote
Old April 20th, 2016, 18:22   #17
jetta ,97
jetta ,97's Avatar
Fuel Economy: Very good
No , I do not , bacuse there is many different options.
Just send me PM (private message ) and I will give you all answers.
I do any repair on all models,USED/NEW ECU and Cluster swap, Reprogramming Keys , Immobilizer Delete,Cluster LCD Dispay Repair -Clik here
I am trusted TDI Mechanic, VCDS
HEX+CAN
ECU TUNING-TDTUNING Authorized Dealer
MK6 Needle Sweep,MK5 with MK6 Cluster
jetta ,97 is offline   Reply With Quote
Old July 23rd, 2016, 07:28   #18
jetta ,97
jetta ,97's Avatar
$25 off on any immobilizer service .
To get discount you need to do send me this link.
HEX+CAN
Old July 25th, 2016, 10:36   #19
Filmshoot
TDI(s): 1.9TDI AFN
Hi can u build me a wire harness so I can upgrade to edc15 from msa 15?
I have an afn motor in my 97 eurovan.
I want the ability to flash from obd port into the 32bit edu
I hate having to make and swap chips in my old ecu
Inscribed with just two thumbs...
Filmshoot is offline   Reply With Quote
Old July 26th, 2016, 06:13   #20
jetta ,97
jetta ,97's Avatar
I sent you PM.
HEX+CAN
Old July 29th, 2016, 15:50   #21
Heavy_D
Default Highly recommended!
Good evening all,
I highly recommend Marin for any ECM work you need to have done. He provides excellent support and customer service. I can't say enough positive things about my experience. I just wish he was closer, so I could use his mechanic services!
I sent in a junkyard ECM for my 2014 Passat TDI to have the immobilizer disabled. Unfortunately, this was not possible, so Marin cloned my ECM instead. Yes, we had to ship the ECMs back and forth a couple times due to the stubborn IMMO, but it was well worth it. It worked like a charm!
I now have a backup ECM in case anything bad happens to the ECM or its programming...
Thanks!
Heavy_D
Heavy_D is offline   Reply With Quote
Old August 24th, 2016, 19:39   #22
jetta ,97
jetta ,97's Avatar
Thank you .
HEX+CAN
Old December 15th, 2016, 21:18   #23
jetta ,97
jetta ,97's Avatar
HEX+CAN
Old December 23rd, 2016, 06:18   #24
02Jetta
TDI(s): 02 JETTA
No one should feel any hesitation to have work done by Jetta ,97!
MARIN did a great job on my immob probem and swapped out my instrument cluster that went bad.
He did everything just as he promised. THANK YOU!
02Jetta is offline   Reply With Quote
Old December 24th, 2016, 20:46   #25
jetta ,97
jetta ,97's Avatar
I am glad I was able to fix everything .
Just to mention that was 2011 Jetta Wagon TDI.
Thank you for trusting me on this.
HEX+CAN
Old December 14th, 2017, 10:25   #26
Strider17
TDI(s): MK4 and MK5
Jetta_97 has helped me with my 2009 2.5L gas to 2.0 CR TDI swap on my 2009 jetta wagon
he knew exactly what he was doing and got it done fast and right the first time around....flawless!!
he was able to take my full FIS cluster from the 2.5L, take my donor half fis cluster from the 2.0 CR TDI and take all the immobilizer and programming and combine it into a FULL FIS diesel cluster i gave him. Along with programming the keys/ECU.
all i did was plugged it in and worked.
update: few months later!
everything still works exactly how it should. no codes and no problems!
I highly recommend his work to everyone and i will definitely be a returning customer of his with my other diesel swaps
Strider17 is offline   Reply With Quote
Old January 29th, 2018, 07:36   #27
jetta ,97
jetta ,97's Avatar
HEX+CAN
Old February 2nd, 2018, 20:14   #28
2005vwmk5tdi
TDI(s): Brm tdi
Hi i am interested in immo off i have 2005.5 jetta tdi brm new body style and 2009 vw jetta 2.5
2005vwmk5tdi is offline   Reply With Quote
Old February 5th, 2018, 07:34   #29
jetta ,97
jetta ,97's Avatar
I sent you Private Message.
HEX+CAN
WTD: Jetta Mk4 ALH Chipped ECU for PP520 + vnt 17 w/ immobilizer delete nubz69 Private TDI Items for Sale/Wanted 4 August 5th, 2014 21:05
Need help Programing immo code in MN aera Thanks in advance greekman Mid-west USA 2 September 14th, 2012 20:58
VW TSB group 17, 03-01, on September 17, 2003 sdgtdi Fuels & Lubricants 6 January 5th, 2010 23:24
Who does EDC-16 tuning for VNT-17/22 on a BKD? surfpilot111 TDI Power Enhancements 2 September 8th, 2009 12:44
hard data on 17/22 ( or equivalent ) turbo upgrades and its MPG affect andrew1984 TDI Power Enhancements 22 January 23rd, 2009 21:42
Page generated in 0.16003 seconds with 11 queries
[Output: 126.29 Kb. compressed to 106.37 Kb. by saving 19.92 Kb. (15.77%)]
