Old March 22nd, 2013, 10:48   #46
JSWTDI09
JSWTDI09's Avatar
Originally Posted by rs999 View Post
Neat Nicktane kit, anyone try using it on a MK6 TDI?
This kit is for a 1999-2005 Mk4 VW. 2micron's filter kit is for a CR diesel (CBEA and CJAA engines). There is little direct comparison, except that both use a 1 or 2 micron spun glass filter. The choice depends on what engine you have and how the filter mounts to the car.
Have Fun!
Don
JSWTDI09 is offline   Reply With Quote
Old March 22nd, 2013, 11:08   #47
ndamico
ndamico's Avatar
hardly,
i have no interest in solving pump design issues on CR tdi's. i don't even have a kit that fits on them. it seeemed he shut his product down because he was using a substandard filter. all i did was give you a suggestion to solve your problem as it seemed people liked his offering.
i make the kits for fun, not for a living. i don't care if you buy one or not. just offering a solution as this filter has been used on the dmax and mk4 for years..i still don't fathom why one would make a nice beautiful bracket for a secondary filter and use a 5 micron unit there. not trying to piss in anyone's wheaties.
nick
Originally Posted by 79TA7.6 View Post
The last two posts should not be in this thread. Nick, it sounds like you are advertising your product on someone elses thread. I am sure this was not your purpose, but that is how it comes across to me. RS, find ndamico's vendor thread and ask there.
14 Passat SE 6-Speed
ndamico is offline   Reply With Quote
Old March 22nd, 2013, 11:26   #48
hotpocketdeath
hotpocketdeath's Avatar
Originally Posted by ndamico View Post
hardly,
nick
There really wasn't anything wrong with using a 5 micron filter, but people were still complaining that they wanted smaller. But most people don't really understand just how small a particle we are talking about here.
He didn't shut down the project, just redesigned it to use 1 or 2 micron filters that screw in place. Easier to change, ability to use a change indicator guage, and is more compatible to mount. Updates have been posted in other threads.
hotpocketdeath is offline   Reply With Quote
Old March 22nd, 2013, 11:31   #49
ndamico
ndamico's Avatar
gotcha.
someone making CR filter kits contacted me a while back about sourceing filters from me. perhaps it was him as you say he is going to a spin-on which is a better idea anyway. he made a good decision.
Old March 22nd, 2013, 11:32   #50
hotpocketdeath
gotcha.
Here's what the new design looks like
http://forums.tdiclub.com/showpost.p...&postcount=168
Old March 22nd, 2013, 11:42   #51
ndamico
ndamico's Avatar
i see. looks like he incorporated my suggestions. that's great! it looks nice and i think it will work out well. i hope this fixes the problems.
Old June 3rd, 2013, 16:33   #52
2004LB7
TDI(s): 2006 Jetta
Fuel Economy: 42/46
anyone have any updates when the Pure Flow HPFP Adapter will be available?
i hate the idea that my HPFP could go out anytime and potentially take out more with it.
2004LB7 is offline   Reply With Quote
Old June 3rd, 2013, 19:42   #53
Lightflyer1
Lightflyer1's Avatar
2micron, the OP, is the only one that knows. I am sure he will post when he has something ready.
2015 Beetle TDI.
Old June 4th, 2013, 13:34   #54
bennybmn
Originally Posted by 2micron View Post
Reserved for the “Drain Flow” Intercooler Kit.
Coming Soon!!!
Go Ahead, Click Them!!!!!
All the best!!
This intercooler drain is interesting... Do you have a kit or is it still in development?
____________________________________________
Euro Switch, Dual horns and powder coated Portos so far... TC off switch soon!
bennybmn is offline   Reply With Quote
Old June 5th, 2013, 17:18   #55
2micron
TDI(s): None
Default Intercooler drain
Hello Benny, Thanks for asking about the Intercooler Drain kit!!
This winter was a great season to test the kit. We had great temperature swings in Ontario and the perfect conditions for gathering water in the Intercooler.
It is really amazing how much water will collect in temperatures just around and below freezing. Another club member also tested the kit all season and had the same results. One common finding is that frequent draining of the system eliminates the chance of water accumulating, then freezing up, causing the startup stumble, choking at speed or worse, Hydrolock.
The valve never froze up, even with deliberate torture testing. (Opening the valve, but plugging the drain end overnight) The "knife action" of the rugged stainless ball valve is very forgiving.
Virtually no water is accumulated when temps are well below freezing. The first warmer 28 degree day brings back the water!!
I was also surprised to see water condensing and collecting in the latest temperatures 15-18 degrees during the day, but with chilly 5-8 degree mornings.
My drive is a constant highway 60-65 mph 1 hour drive, perfect for collecting water.The only issue and revision is that the actuating rod rattles a little bit. A little bit of rubber grommeting and such will help.
As far as The Intercooler Drain kits, sure, if there is any interest. But not until the fall of this year and certainly after the Fuel System kits are out there and helping to keep our fuel systems alive!!
Thanks,
All the best,
Andrew
2micron is offline   Reply With Quote
Old June 6th, 2013, 12:45   #56
bennybmn
Thanks for the replies and PMs!
Old July 7th, 2013, 18:49   #57
2micron
TDI(s): None
Default Contain Flow and Pure Flow Update!!!
Hello All!!
Thanks for being and continuing to be patient!!!
A few kits are starting to trickle out!!
Please see the very first page of this thread for more pictures and Pricing!!!
The current Kits continue to trickle out and if any revisions are required, I will certainly update!!!
Check out the latest thread about the Pure Flow, showing installs, questions and feedback from our members!!!
http://forums.tdiclub.com/showthread.php?t=389392
Here are a couple of the latest pictures!!!:
Pure Flow and Contain Flow kits together:
Pure Flow and Contain Flow kits together, exploded view:
Installed together:
Thanks again,
All the best!!!
Andrew
Old July 7th, 2013, 20:11   #58
LOUDERMAN
LOUDERMAN's Avatar
Fuel Economy: Enough to keep me happy.
Definitely interested in the IC drain. Even though I live in AZ I have this nasty habit of driving up to where the snow falls every now and again. Probably just to verify why I live in the valley...
Economy, Longevity, and Performance. Suck it Prius!
LOUDERMAN is offline   Reply With Quote
Old July 8th, 2013, 05:14   #59
Growler
Got Soot Vendor
Growler's Avatar
so it looks like to change the normal factory filter you would have to disconnect the hard line over to the filter mount with the gauge on it?
looks like a nice kit Andrew. I might have to get one of these to put on the shelf so I have one to offer to my occasional CR customers.
I know I would own one of these if I had a CR TDI myself.
~Aaron~
Schmutz 2015 GSW S DSG
Schnurren 2001 Golf 2 door.
Old July 8th, 2013, 05:30   #60
kjclow
Fuel Economy: 55 max / 44 avg on beetle ~37 on JSW
Thanks for all this work Andrew. Now that I have a price, it's on my list.
2010 silver/black JSW TDI with DSG, 2011 red Golf TDI with dsg, 2003 red/gray Passat 1.8l gasser
kjclow is offline   Reply With Quote
Diesel Power Tuning Modules for VW Common Rail at kermaTDI VailPowder Vendor & GroupBuy items for sale 32 March 18th, 2015 17:18
VW utilisera un common rail en 2008? Nico3d3 Quebec 4 June 26th, 2007 16:41
Common Rail Drivbiwire TDI 101 1 June 23rd, 2006 06:15
VW move to Common Rail TDIdragon TDI News/Tech 81 June 12th, 2006 05:55
VW TDI common rail flappie VW MKIV-A4 TDIs (VE and PD) 77 May 25th, 2002 22:08
Page generated in 0.19732 seconds with 11 queries
[Output: 137.20 Kb. compressed to 115.53 Kb. by saving 21.66 Kb. (15.79%)]
