Old February 6th, 2013, 18:52   #16
schultp
schultp's Avatar
Originally Posted by JSWTDI09 View Post
This is exactly the reason why I have no intention of removing my return filter. It will stay in my car - at least until 2micron comes up with a better design.
Have Fun!
Don
Mine will stay on my car. I still am using the original bracket. I do wish I got one of the new brackets simply for the elegant look of this solution! But, the original bracket certainly serves my needs.
The problem will continue to be that someone will always point out that whatever we filter out there will still be a chance of a smaller particle getting through and causing damage. Since we cannot do the definitive testing these naysayers will always be able to claim they could be correct. But an important point is that I never considered Andrews products as some sort of guarantee that the HPFP would never fail but that the damage would be limited to only the pump (if using both the Contains Flow and Pure Flow products).
Also, I suppose one proof that sub 5 micron particles are less of a concern to the VW engineers is the fact that the main OEM fuel filter has a micron rating that is above 5 micron from what I recall. Seems like they didn't have worries about the need to filter down to less than 5 microns. I wonder what kind of sub 5 micron particulate crap is in our diesel fuel to begin with?
Paul.
2010 JSW TDI, 6sp manual
schultp is offline   Reply With Quote
Old February 8th, 2013, 08:45   #17
elkriver
It would increase the cost but Nicktane's Uber filter looks about as good as anything available. Don't think it would fit the mount as currently configured. And, it wouldn't do anything to increase the effectiveness of the stock supply filter. If the folks who complained want perfect, it isn't available. People like them would rather live with the status quo. they must be under 60k miles.
elkriver is offline   Reply With Quote
Old February 8th, 2013, 09:12   #18
KITEWAGON
KITEWAGON's Avatar
I love the drain flow intercooler kit. Nice work. I'll definitely consider one for our car, though the problem is that my wife would never remember to use it.
On the return fuel filter I would be curious what the potential cost savings is for having this device in the event of an HPFP failure. I still don't have a handle on what the 'real' not dealership repair cost is for that failure, but I'd be curious if this would reduce the repair by $500 or several thousand.
EDIT: Sorry to post this in the vendor thread. I just realized that there was a whole other thread for discussion on this part.
2014 Touareg TDI Executive, Canyon Grey, 130k
2014 JSW TDI, Platinum Grey, 43k
2005 Toyota Tundra Double Cab SR5 TRD 4x4, Silver, 165k
KITEWAGON is offline   Reply With Quote
Old February 8th, 2013, 11:37   #19
JSWTDI09
JSWTDI09's Avatar
If the filter works as planned (which is what the current controversy is about) it would drastically reduce the cost. Currently it is in the 7-10 thousand dollar range - replacing the entire fuel system from tank to injectors. With the return filter alone, you would only have to replace the HPFP, fuel rail and injectors. With the filter and 2microns HPFP mod, you would only have to replace the HPFP and one fuel filter (under $1000 in parts). This, of course, assumes that the filter actually catches all of the HPFP debris particles. Since there has not yet been an HPFP failure with these parts installed - this is all conjecture, not fact.
Have Fun!
Don
JSWTDI09 is online now   Reply With Quote
Old February 8th, 2013, 12:20   #20
LNXGUY
LNXGUY's Avatar
Isn't 90% of that repair cost in the HPFP and injectors?
Bill
LNXGUY is offline   Reply With Quote
Old February 8th, 2013, 13:03   #21
Lightflyer1
Lightflyer1's Avatar
Parts maybe. Labor is probably half to start with.
2015 Beetle TDI.
Old February 8th, 2013, 20:22   #22
TDIJetta99
TDIJetta99's Avatar
Fuel Economy: low 38, high 61, avg 48
Most of the time is swapping the pump and injectors too.. Cleaning the tank takes a ton more time than replacing it too..
Taking on some work here and there.. Contact me for your needs.. Can do emissions testing friendly ALH tunes on most setups, even swaps. best way to contact is text or email tdijetta99@gmail.com
TDIJetta99 is offline   Reply With Quote
Old February 9th, 2013, 13:49   #23
wanabe
I agree with your logic but it seems that the system needs a better filter than comes standard. I.e., the engineers were wrong. Otherwise we would not need to replace parts upstream from the filter. I have a vague memory from years ago that Bosch specified the filtration needed for the HPFP but I can't find it now. If the filter meets those specs then it is the Bosch engineers that were wrong. Does anyone have those specs?
09 JSW manual Laser Blue/Anthracite built 08/08 (HPFP built 5/21/2008 WITH RIDGES)
wanabe is offline   Reply With Quote
Old February 10th, 2013, 04:35   #24
ihatespeed
Fuel Economy: 40mpg city 46 avg, 50 hwy 33 trailer
I wouldn't take my contain flow off if you told me it sold crack in the elementary school. Id love to get the pure flow as well.
As far as I'm concerned a 5 micron filter is so much superior than passing pump guts straight back to the clean side of the stock filter where it is free to go unimpeded right back through the fuel rail again, its not even funny.
Andrew's 3rd generation (2Micron.com) return fuel filter, and Pure Flow HPFP modification.
ihatespeed is offline   Reply With Quote
Old February 10th, 2013, 09:18   #25
joeelmex
Can we still buy them if we want? I will rather have some protection over no protection. Keep up the great work.
joeelmex is offline   Reply With Quote
Old February 10th, 2013, 10:23   #26
JSWTDI09
JSWTDI09's Avatar
I do not know if 2micron is closely following these threads. It appears that there are many members here who are aware of the possible limitations of this kit and want it anyway. I would suggest sending PMs to 2micron. I do know that he has about 30 of these kits built, but he has officially suspended sales due to concerns about it's usefulness. If enough people tell him that they are aware of the issues and still want to buy it, he might be willing to sell some more. I cannot speak for him, but it can't hurt to ask.
Have Fun!
Don
Old February 13th, 2013, 19:34   #27
elkriver
I can rig up my own return filter set up but I can't machine my own Pure Flow adapter. Do we know if these will ever be available?
Old February 13th, 2013, 19:47   #28
bhutchins
bhutchins's Avatar
Fuel Economy: best 47
a lude analogy, but a condom is 99%, not 100% but close. not using one is looking for trouble. you want one that's 100%???
5uM filter is not 100%, but 99%, go without and you could be looking for trouble. I know, I've got a tween and a teen. lots of touble, but worth it.
Sold : 234 WHP / 404 WTQ (550 N-M)
bhutchins is offline   Reply With Quote
Old February 14th, 2013, 09:00   #29
paramedick
paramedick's Avatar
I'm eagerly awaiting the availability of both products
Old February 14th, 2013, 09:02   #30
bobt2382
bobt2382's Avatar
Fuel Economy: 46.5
I'm eagerly awaiting the availability of the Pure Flow adapter!
2010 4D CWhite Golf TDI, 6 sp manual, Fluidampr, Bixenons, Rear Airbags, RNS-510, Dynaudio, DieselGeek SS & P2015 bracket, Force Fed Eng. Shifter Bushings. XB,UB, & RB UNIbraces; TyrolSport Brake Caliper Bushing, 2Micron Contain/PureFlow kits & timing belt cover, PolarFis MFD module, Euro light switch, R Red LED Tail Lights,Under Seat Drawers, Full color MFD cluster.
bobt2382 is offline   Reply With Quote
Diesel Power Tuning Modules for VW Common Rail at kermaTDI VailPowder Vendor & GroupBuy items for sale 32 March 18th, 2015 17:18
VW utilisera un common rail en 2008? Nico3d3 Quebec 4 June 26th, 2007 16:41
Common Rail Drivbiwire TDI 101 1 June 23rd, 2006 06:15
VW move to Common Rail TDIdragon TDI News/Tech 81 June 12th, 2006 05:55
VW TDI common rail flappie VW MKIV-A4 TDIs (VE and PD) 77 May 25th, 2002 22:08
Page generated in 0.18168 seconds with 11 queries
[Output: 133.09 Kb. compressed to 111.32 Kb. by saving 21.77 Kb. (16.36%)]
