Old August 19th, 2009, 12:06   #1
fgbrault
fgbrault's Avatar
Default New Guinness mileage Record TDI/Goodyear
The Taylors using the same 2009 TDI as they used to previously to set the Guinness record for circumnavigating the contiguous USA set a new record of 67.9 mpg, beating the 58.8 mpg they set last year. They used the new Goodyear Assurance Fuel Max tire and droe the same route as last year.
This is quite impressive. Has anyone tried this new tire?
The reviews at the TireRack seem mixed.
http://www.tirerack.com/survey/Surve...irePageLocQty=
Here is a link to the TDI article.
http://news.prnewswire.com/DisplayRe...5079576&EDATE=
Regards,
Frank B
DSG, Sedan, Platinum Gray, Art Gray Build Date 10/08
fgbrault is offline   Reply With Quote
Old August 19th, 2009, 15:51   #2
DoctorDawg
DoctorDawg's Avatar
I would love to believe that the right tire could improve my fuel economy by 9 MPG.
But I don't.
Sounds like the Taylors had a tail-wind this time.
2009 Jetta TDI (Loyal Edition, Campi White, DSG, #1470, built 5/08): 56K miles and zero problems 1/16/2011.
WeatherTech deflectors, Dieselgeek skid plate (both A+)
My other diesel gets 120 MPG (minutes per gallon): Kubota 2630 w/ FEL
My other other diesel I don't even want to talk about (1995 Dodge Ram 2500 Cummins 4x4)
DoctorDawg is offline   Reply With Quote
Old August 19th, 2009, 16:08   #3
CMB430
I would like to know if this is the same car used last time...and how many miles are on it. Plus, if I am not mistaken is true that you usally get better mileage driving west to east?
I do not think they even carried a spare bottle of water in the car, and the must never have taken the engine above 2200 RPMs. But, I would rather hear about this in a TDI than a Honda or Toyota.
NEW: 2011 Frontier
SOLD at 44K miles: 2009 Jetta TDI, 6M, fog lights, protection package.
CMB430 is offline   Reply With Quote
Old August 19th, 2009, 16:47   #4
DoctorDawg
DoctorDawg's Avatar
It has always seemed to me like customer reviews at TireRack are always mixed. You ask ten guys what they think about a tire, you'll get twelve widely different opinions.
One fairly common theme in the reviews does seem to be that the sidewalls are kinda soft and wiggly, leading to degraded performance in turns. That dog won't hunt.
Old August 19th, 2009, 17:25   #5
chimmike
TDI(s): 05.5 A5
buying a tire that claims it'll improve fuel economy is a crock to me.
a tire that gives good mileage will be a hard compound, firm tire that won't have give in it. A tire like that will be rough riding, slippery in rain conditions due to hard compound, and will have good cornering characteristics.
Run a tire that you like, and run 35psi all around and you'll be fine.
I had a set of Yokohama Avid H4's in the past and they were excellent. Super quiet, excellent in the rain, rode nice and had a really long tread life.
chimmike is offline   Reply With Quote
Old August 19th, 2009, 20:45   #6
fgbrault
fgbrault's Avatar
My understanding frm the article is that it was the same car.
Regards,
Frank B
Old August 19th, 2009, 20:53   #7
frugality
frugality's Avatar
Fuel Economy: 33mpg
...and they pi$$ed off even more people by driving like a granny.
With regards to the wind, it shouldn't matter if it was a circumnavigation (a loop.) One-way coast to coast, there would probably be a noticeable difference whether it was E to W or W to E.
2016 GTI SE 6M with lighting package, runs on RUG, has spark plugs? AVERAGING 33mpg!
2010 Jetta Sportwagen TDI, 197,089 miles, Silver, manual, 17" Goals, original brakes -- GONE; REPURCHASED BY THE MANUFACTURER.
frugality is offline   Reply With Quote
Old August 20th, 2009, 20:52   #8
raybo
Fuel Economy: 2001 Golf (SOLD 11/15/15): 45 MPG avg mostly highway; JSW high 30's around town
My only experience running underrated tires was when I put 89H Dunlops on our old '88 300E. The manual called for 91V (later reduced to 91H for the identical '89 and later years probably due to limited sources for 91V 15 inch tires).
It was a mush machine. When I replaced the 89H with Bridgestone 91H, it handled like a different car. I'll never run under-spec tires again.
Ray
SOLD 11/15/15: 2001 Golf GLS 5-Speed Reflex Silver 391K
GOT 11/15/15: 2016 GSW S 1.8 TSI 5-speed Reflex Silver
2010 JSW DSG White Gold Metallic/Corn Silk 105K | Pano | Liqui Moly Top Tec 4200 as of 50K | Continental PureContact | built 11/09 (hers) HPFP disintegrated 12/14 - entire fuel system repaired by VWoA Jan 2015 at 93K miles
raybo is offline   Reply With Quote
Old August 21st, 2009, 13:26   #9
Turbine Suburban
Makes me wonder if they were chained to a truck for that record.
FWIW, in airplanes, you get headwinds about 70% of the time.
Turbine Suburban is offline   Reply With Quote
Old August 21st, 2009, 20:59   #10
fcatwo
TDI(s): 2009 JSW DSG
I've read that there are limits to how hard tires can be before they decrease rather than increase mileage. The theory is that an overly hard tire will be constantly impacting road imperfections and jumping over them while the soft-sidewall tire will absorb the impacts with less energy loss. It sounds like Goodyear has bought into the soft-sidewall approach for their maximum-mileage tires.
2009 JSW-DSG
fcatwo is offline   Reply With Quote
Page generated in 0.17247 seconds with 10 queries
[Output: 95.09 Kb. compressed to 80.06 Kb. by saving 15.03 Kb. (15.81%)]
