Matt_Seattle
This forum seems like a good place to ask for advice on getting what value I can out of my Jetta. IT has a leaking turbocharger that needs replacing- $1800. The mounting bracket that holds the engine thermostat and coolant temp sensors in place has broken- $500ish. The left axle shaft is throwing grease and needs replacing- $?. Anyway the service shop estimated $3400 in repairs. The KBB value of the car is similar.
I am not inclined to repair it. I've spent enough on it and I'd rather put that much cash towards a DP on something new. Any advice on how to proceed?
Basic info on the car:
162,709 miles
Timing belt, belt tensioner & roller, water pump, fuel pump replaced last summer. Rear tires replaced last month. "Panzer plate" installed. Windows tinted. Rear brakes close to replacement.
THanks,
Matt
162,709 miles
THanks,
Matt
