Roy Basch
- Joined
- Oct 8, 2000
- Location
- Brookfield, IL
Well I should have put things back together when I saw this:
I decided that with 70k miles on my 96 Passat things must look a lot worse deaper in the intake manifold. I started having trouble with the bolt on the far passenger side (the turbo-in plastic pipe was getting in the way) so I flexed it a little
The bottom portion that attaches to the turbo ... matter of fact it still is attached
To top it off it looks like the allen is stripped on one of the bolts and I have the oil supply for the turbo obstructing an other.
Well, looks like I'll be heading to the stealer tommorow to see how much the pipe costs.
Roy Basch
96 Passat TDI
Roy Basch
96 Passat TDI
