PoochiePD
I am experiencing a small vibration at approximately 1900 rpm that goes away at 2k rpm but comes back with a vengeance at 3500 rpm and goes until pretty much redline. It has this vibration in any gear and is dependant on rpm and load. (It gets slightly worse with a load on it.)
I ordered a Spec Stage II+ clutch upgrade with the G60 Eurospec flywheel (supposed to be 14 lbs) to replace my stock clutch and DMF, received it, and had it installed by a very trusted TDI guru. Problem is, I didn't actually make sure I got the correct flywheel when it came in the mail. It turns out that instead of the 14 lb flywheel, I was sent the ultra-light-weight flywheel (I think 8 lb). Unfortunately I did not discover this until it was installed and mentioned this vibration to the guru. The guru drove my car when it had over 500 "nice" miles on the clutch and said that his upgraded Jetta had the same vibrations, just not nearly as pronounced. (He has a stock weight G60).
I really wasn't too worried about the extra vibrations from a SMF but this seems pretty severe compared to what I was expecting.
My question is, should I worry about it? I read up on it and general consensus was that a light-weight FW won't hurt anything, but no one mentioned the kind of vibrations that I am experiencing, or, for that matter, I don't think I saw ANYONE with an ultra-light-weight SMF on a PD. I can easily get used to it, but I just don't want to ruin anything...
I should also mention that the passenger drive axle was replaced at the same time, could that possibly be a contributing factor?
This is on a 2005 Jetta with RC Stage 1.
