2005 4dr Golf Silver 5spd in Michigan
fungi131
MI
2005 golf
I’m selling my car, extra parts, tools, and computer. I have a 2005 Golf in reflex silver 5spd BEW with 266,165 miles. I have purchased all my maintenance parts from forum vendors. The turbo came from X-Man and we all know about Franko6’s camshafts.
I have a large folder with thousands of dollars worth of invoices and receipts that will go with the car.
I have done all the work on the car myself except for the tunes, thankyou RocketChip! I have used Schaeffer’Supereme 9000 5w-40 engine oil since installing the new camshaft.
Everything will be sold together for price drop $1900 for forum members
Current modifications/upgrades/maintenance (Date of Install):
Evolution skid plate 5/2016
Espar Eberspacher Hydronic III D5E coolant heater 12/2017
1756 hybrid turbo 1/2017
Upgraded SMIC 9/2015
2” upper and lower turbo piping 9/2015
Pd150 injectors 10/2016
Custom RocketChip tune (Approx. stage 4) 10/2016
Franko6 stage 2 camshaft, cut bearings, and lifters 9/2016
DC stage 2 clutch and SMF, Flywheel: 21 lb 10/2016
Boost gauge and EGT sensor 9/2016
Brakes pads and rotors, Koni Red shocks struts and springs, bushings, ball joints and tie rods inner & outer 3/2015
Summer tires on 17” VW Seattle wheels 6/2016 (apporx. 1500 miles)
Winter tires on 15” VW Jaram wheels 9/2016 (approx. 1500 miles)
Timing belt service 9/2016
Midwest Light Creations HID headlights 2/2018
Kenwood Bluetooth radio 9/2015
Vented passenger front fender liner 9/2015
Fumoto oil drain plug
Current problems:
Central locking problems with passenger’s rear door and the driver’s front door.
Rust on both front fenders.
Dent on driver’s front fender.
Scratches and small dings on both back doors.
Antenna base has water damage (no radio signal).
Glow plug harness shorting on #3 cylinder.
Second gear synchro is worn.
Included with the car:
New OEM glow plug harness.
SKC and three aftermarket switchblade keys and their remotes.
VCDS cable (k2 usb).
VagTacho cable and software.
Older Samsung laptop.
Original PD100 injectors.
Assorted new OEM fasteners, gaskets, washers, oil filters, and fluids.
The old Frost Heater I had on the car before installing the Espar.
Metal Nerd: timing belt tools and strut wrench.
Digital copy of the Bentley service manual.
https://kalamazoo.craigslist.org/cto/6694590765.html
