Go Back   TDIClub Forums > TDI Model Specific Discussions Areas > Audi SUVs (Q7 & Q5) and other V6 TDIs
Audi SUVs (Q7 & Q5) and other V6 TDIs Discussions area for Audi Q7 and Q5 TDI (2009+ in Canada & the US) as well as others with the V6 TDI such as the A6, A7 and A8 sedans.
Old May 22nd, 2018, 07:25   #46
Jetta_Pilot
Jetta_Pilot's Avatar
Location: West Hill, Ont. Mexico mid October 2017 to end of April 2018
Originally Posted by Mythdoc View Post
Well, if there was no warranty, I’d be right there with you on the ECU tune. As it is, I have a warranty through 2024, that I don’t want to imperil.
Well I also bought the Flashzilla tool with my tune so I can revert back to stock if I need to take the car back for anything other than an oil change. I do understand they can tell, but I also think it isn't too likely that they will check. Yes I too have an extended warranty and if or when I get the Phase 2
there will be an extension.
All interior bulbs to LED. Several VCDS modifications. Darker window tint. EVO skid-plate. Malone Stage 2, Winpower Projector headlights. Angel eyes.LED DRL's.24mm H&R rear sway bar.
Old June 7th, 2018, 17:46   #47
Mythdoc
Mythdoc's Avatar
Update: I turned the Chipwerke module up another notch and love the extra power. Too soon to report on fuel efficiency. Still problem free.
“Yeah, well, y’know, that’s just like, uh... your OPINION, man.” —The Dude
2015 Q5 TDI w/ Chipwerke tuner, 30K Miles
2011 Touareg TDI 74K Miles (sold back to VW, May, 2018)
2015 Golf TDI 22K Miles (son’s)
Mythdoc is offline   Reply With Quote
Old July 19th, 2018, 14:44   #48
QCTorqueAddict
Just bought a Chipwerke module. Not installed yet. Are you using B-1 setting like the instructions or did you change something?
QCTorqueAddict is offline   Reply With Quote
Old July 20th, 2018, 06:38   #49
Mythdoc
Mythdoc's Avatar
Default Chipwerke Piggyback Tuner: 3.0 Dieselgate Solution?
I recently turned it up to D-2. Works very well. Lots of turbo boost available when running lower rpms on a fully warm engine.
Old July 20th, 2018, 14:06   #50
QCTorqueAddict
Thanks. I'll try that.
Old July 25th, 2018, 03:50   #51
QCTorqueAddict
Tried it on D-2. There was a loud "diesel clatter" around 2000 RPM but the acceleration was great. I switched to B-1 and the clatter is gone. Will try it a few days.
Old July 25th, 2018, 05:18   #52
Mythdoc
Mythdoc's Avatar
Yep. There is some clatter on mine, I think it is maybe closer to 1800, but I like it, lol. Let us know your other findings, including fuel efficiency.
Old July 25th, 2018, 12:28   #53
mike
mike's Avatar
Fuel Economy: Q 34, ALH 49/45/43
It is possible to restore the old tune with the higher mpg's then!
Sounds like the way to go if you haven't been fixed yet.
Anyone actually restored the old tune this way?
mike is offline   Reply With Quote
turning soot into ink -- solution to dieselgate? diesel#2 TDI (Diesel) Emissions 2 March 13th, 2017 11:16
Chipwerke TDI Pro S Chip - PiggyBack T1no33 TDI Power Enhancements 0 September 18th, 2015 11:46
Piggyback on the 1.9 ALH vogelspinnen TDI Power Enhancements 7 August 17th, 2011 19:54
cheap flash tuner solution BlakGolf TDI Power Enhancements 84 April 13th, 2007 16:28
Page generated in 0.16005 seconds with 12 queries
[Output: 89.80 Kb. compressed to 77.72 Kb. by saving 12.09 Kb. (13.46%)]
