Old April 9th, 2018, 07:00   #1
KITEWAGON
KITEWAGON's Avatar
Default OSRAM XENARC LED XENON Lights
I'm looking for feedback on these lights. I am currently looking into options to upgrade or replace my stock halogens. After having the GTI with lighting package its tough to go back to lousy halogen lights. Though I don't do a ton of night driving, when I do I light to be able to see.
These are an interesting option that I found. But I can't find much information on them at all which probably isn't a great sign. They have a MK7.5 look with the LED DRL's. But they look high quality as opposed to most of the aftermarket eBay junk.
I'd love to see pictures of these on a JSW, but google hasn't been a help. The really odd thing is that I can't even find a listing of these for sale to see what the pricing is like.
https://www.osram.com/am/light-for/l...ghts/index.jsp
2014 Touareg TDI Executive, Canyon Grey, 130k
2014 JSW TDI, Platinum Grey, 43k
2005 Toyota Tundra Double Cab SR5 TRD 4x4, Silver, 165k
KITEWAGON is offline   Reply With Quote
Old April 9th, 2018, 07:58   #2
20IndigoBlue02
20IndigoBlue02's Avatar
They use D8S bulbs, which are 25W bulbs, which are down around 1200 lumens compared to the factory D3S 35W/3200 lumen bulbs.
2016 Tiguan SE 4Motion
20IndigoBlue02 is offline   Reply With Quote
Old April 12th, 2018, 12:18   #3
KITEWAGON
KITEWAGON's Avatar
Thanks for the feedback on bulbs. That is something to keep in mind. I think that these lights have only been out for about a year. They appear to be available through one european vendor for around $1k, which is pretty steep. I think that I like the look, but I couldn't find a single picture of them installed on a sportwagon.
Unfortunately I still can't find a lot of information on them. But I did find some forum post reviews that indicated quality issues (such as the DRL's jiggling in the housings) and lousy customer support. For that kind of money I'd want to read glowing reviews and that they have great customer support.
So even though I think these look pretty cool, I'm going to hold off for now. Maybe look for used OEM or see if a used set of these to show up.
If anyone is selling OEM MK6 bi-xenon's let me know! At this point my preference would probably be to avoid attempting the auto-leveling because of the complication associated with them. I don't want to get into swapping modules or advanced coding. I don't mind editing a little bit of long-coding if there are clear instructions, but that is the limit of comfort level.
Old April 13th, 2018, 12:35   #4
KITEWAGON
KITEWAGON's Avatar
Well I drove in the dark and the rain last night for the first time last night. The halogens are even worse than I remember after using HID lights for year. So I'm going to have to come up with a solution sooner rather than later. I can't believe how bad the low beams are in particular. I don't think that I have particularly good night vision and perhaps that is part of the problem. But with HID's I can see great because they light up the road like daylight!
I read that mfr's use the 25W bulbs because its easier for them to get DOT approval without using washers and leveling systems. I'm sure even 25W bulbs would be a massive improvement over the halogen lights.
Old April 13th, 2018, 16:05   #5
20IndigoBlue02
DOT regs don't require auto level nor headlight washers.
It's ECE regs
Old April 20th, 2018, 21:25   #6
Wilkins
Fuel Economy: 4.6/5.6 - 5.3/6.7
How bad the low beams are???! I never had a problem with the low beams before I installed Xenons, it was the insipid high beams. Yes the OEM Xenon has a better low beam than the halogen but if your problem is low beams I would check the voltage drops across the bulbs to make sure you don’t have a wiring issue before spending a pile of money.
I’ve spent time driving the company Silverados with the 25 watt HIDs and they are not bad, significantly better than a LED Ford, yet many people complain about the lack of light. Depends on what you expect perhaps.
2005 Jetta Wagon: Evo skid plate, Kerma Tune, Moog VR6 front springs, Koni Reds, Jeff's HID's, Upgraded door switches!. MKVI: Containflo+Pureflo, Rear Tiggy springs and B6 Billies, Xenon w LED, AFS, 087T BCM
Wilkins is offline   Reply With Quote
Old April 21st, 2018, 08:24   #7
meangreen
meangreen's Avatar
TDI(s): 2001 Jetta
Fuel Economy: Who cares as long as it is more than 600km/tank,and you have power
You should contact freekwithracket here on the forum. He is in the vendor section and he might be able to help you with your old light and retro fit them to hid. He does nice work
meangreen is offline   Reply With Quote
Old April 21st, 2018, 09:47   #8
KITEWAGON
KITEWAGON's Avatar
Originally Posted by Wilkins View Post
How bad the low beams are???! I never had a problem with the low beams before I installed Xenons, it was the insipid high beams. Yes the OEM Xenon has a better low beam than the halogen but if your problem is low beams I would check the voltage drops across the bulbs to make sure you donít have a wiring issue before spending a pile of money.
Yeah both low and high beams are terrible after getting used to HID lights. At this point my plan is to look for OEM HIDs from a GTI or Golf R. I'm not thrilled with having to swap out some kind of control module and do a bunch of coding, but that seems like the best way to get back to having high quality lights. I plan to own the car for a long time so I might as well be able to see at night.
Old April 29th, 2018, 15:03   #9
2dedge
TDI(s): jetta
Please keep us posted
2dedge is offline   Reply With Quote
FS: OEM Replica Headlights 'Ed Lights' MK6 10 LED Dual Projector Xenon HID Low Beams LoganB Private TDI Items for Sale/Wanted 3 June 18th, 2013 16:04
HowTo: OEM Bi-Xenon/OEM Fog Lights/CECM Upgrade/LED Euro Tails in a 2010 Jetta Sedan amd is the best Upgrades (non TDI Engine related) 69 May 25th, 2013 13:02
Xenon LED/Combo? dan30thz28 VW MKIV-A4 TDIs (VE and PD) 1 June 21st, 2012 20:39
Mk6 Golf non-LED to LED xenon coding help veedubu Upgrades (non TDI Engine related) 0 April 22nd, 2012 07:43
OSRAM LED Daytime Running Light DRL chowster1 Upgrades (non TDI Engine related) 2 March 1st, 2011 22:34
Page generated in 0.14919 seconds with 12 queries
[Output: 94.24 Kb. compressed to 80.76 Kb. by saving 13.49 Kb. (14.31%)]
