thordehr
I was 30 miles from home on the freeway when we heard a clank, thud, thud, thud, looked at each other, then I looked in the rear view mirror to see something bouncing in the road and bounce off the bumper of a following car. I exited the freeway, took a look and the alternator pulley was gone yet the belt was still in place and belt still running all the other accessories. Got back on the freeway, turned off all the accessories and kept going. I also turned off the daytime running lights by pulling the parking brake to the first click, just enough to turn them off yet not actually apply any parking brakes. Tried to save as much power as possible to run the injection timing. Well, I made it home and the belt stayed on the whole way. It was riding on the alternator shaft and the adjuster had enough throw to keep it tensioned. Apparently the shaft was smooth enough not to shred the belt and the belt may have been heating the shaft up on one face but the heat to the belt was spread through it's entire length so wasn't enough to heat damage it.
Going to take it in and have them fix it under warranty, will probably have them check the harmonic balancer as well.
Still amazing to me that I threw the balancer out of the car but not the belt and was able to retain the belt running all other accessories all the way home.
