Well i posted in the fist post its a 98 Jetta TDI 5spd.
has 95,xxx miles
I have rebuilt engine after i bought it with a damaged head.
replaced:
the 109 relay
Ign switch
glow plug relay
all new glow plugs
checked allother fuses and relays
found out check engine light was burnt out so i replaced it
etc
Bought Bently manual and have spent all hrs looking at wiring diagrams
Took it to autozone they were able to pull codes. I didn't get all the numbers cause autozone staff is something to be desired. I was mainly concered with the fact that the scanner was able to connect.
It seems my Vag-com software/cable have an issue.
Found out the alt is back feeding and causing the run on prob. If the 2 wire connector is unplugged it starts and shuts off as it should. Alt charges after i rev it to excite it.
Checked K-wire for radio it has an aftermarket and the diag wire is not connected to the radio. It checks out fine. But i have the radio un plugged and pulled out of dash along with the data connector an all the center dash. Have had the cluster out too.
http://forums.tdiclub.com/showthread.php?t=294633
I started a thread earlier explained everything listed all my new parts and all the details. Two people replied. So here i wrote very little. KISS Keep It Simple Stupid. I got more responses and feeback.
As i work out in the garage on the wknds the only free time i have its hard to spend lots of time writing long post with every tiny detail. I asked a simple question and go from there.
Sorry to waste your time with my lack of minor details. Thanks to others for their ideas and suggestions.
I will look into the shorted wires with reverse lights as the wires from the alt have some sheathing torn and enter the harness riht where the reverse light switch does.
