DJGeorge
My backup lights aren't working and I don't know that they ever have in the 2+ years I've had the car. The fuse is OK and I've replace both bulbs.
Using a voltmeter, I checked at the bulbs and see no voltage. But if I remove both bulbs, I can see 12V at the sockets on both lights. As soon as I put a bulb in either socket, I can't see the voltage anymore. Sounds like a grounding problem.
Has anyone any experience with this same problem? Is there a troublesome area for the ground connection to the tailgate? All other electical components work (knock on wood) so this seems to be a localized problem.
