Old April 20th, 2017, 08:06   #16
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
Originally Posted by tdiatlast View Post
...there's just no way 4 qts. could disappear w/o additional issues...
Now I'm wondering if a moderator should delete this entire thread, to keep the potential of misinformation from spreading on the internet. The title is rather hysterical, isn't it????
That is exactly my point. Trying to plot a trend via one data point is not only misleading, it is completely UNleading. It has no direction.
oilhammer
www.cardocautomotive.com
Old April 20th, 2017, 08:28   #17
Lex Tdi
TDI(s): 2013 Passat
Confirm change and that it is refilled properly and see what happens over the next month. If no oil is consumed you know the dealership fed you a line. If you do start to see some usage you know have something to investigate more thoroughly...
If it used 4 qts it gonna keep using, an engine doesnt just magically decide its full...
2013- Passat SE DSG 155,000 miles
RIP 2003 Jetta - 444,000 miles
SOLD 2001 Jetta - 300,000 miles
Thanks to Paramedick (Bruce) for being my local Guru for over a decade!
Lex Tdi is offline   Reply With Quote
Old May 1st, 2017, 11:14   #18
LarBear
Our '13 Jetta, sadly now gone, used maybe a cup of oil when brand new, then nothing at all for the next 26k. Something wrong. Either they didn't fill it with oil, or if they're using 505 instead of 507 maybe that's the problem.
LarBear is offline   Reply With Quote
2012-2013 Passat Turbocharger Warranty Extended to 10 years/120,000 Miles! cevans VW Passat Family (NMS and B7) TDIs (2012+) 147 July 28th, 2014 15:34
New 2013... 1/2 quart oil burned at 1200 miles nullsignature VW MKVI-A6 Jetta Sedan (~ 2011+) 32 July 26th, 2013 19:00
Recap: 12 Months and 39,000 miles on a used Passat wagon s4phillips VW B5 Passat TDIs 4 November 22nd, 2009 18:13
Burned Out Glow Plug at 9,000 Miles PDJetta VW MKIV-A4 TDIs (VE and PD) 13 June 28th, 2004 13:15
30,000 miles on 5 quarts overfill (1/2 qt. dirty) a problem? Rus VW MKIV-A4 TDIs (VE and PD) 7 August 8th, 2001 11:32
Page generated in 0.16094 seconds with 11 queries
[Output: 60.03 Kb. compressed to 54.58 Kb. by saving 5.44 Kb. (9.07%)]
