Go Back   TDIClub Forums > TDI Model Specific Discussions Areas > VW MKVI-A6 Jetta Sedan (~ 2011+)
VW MKVI-A6 Jetta Sedan (~ 2011+) Discussions area for the MkVI (2011+) Jetta sedan. This model was originally codenamed NCS (New Compact Sedan).
Old June 8th, 2012, 11:41   #1
Organdonor
Organdonor's Avatar
Default Intercooler icing fix kit backorder.
Only took 5 months, LOL.
Got the call yesterday that it arrived at the dealership, made the appt for them to install it next week.
Ordered it in January!
Organdonor is offline   Reply With Quote
Old June 8th, 2012, 12:54   #2
Sparer
Fuel Economy: 42 mpg
So are they doing this on an "as-needed" basis or is this basically a recall? I have a 2012 and living in Illinois scares me that I am going to run into this. i would much rather get it out of the way while its warm than need it done in january
Sparer is offline   Reply With Quote
Old June 8th, 2012, 13:22   #3
cd_booth
Fuel Economy: 35/45
Read up on one of the many other threads about this. In short, you will only get VW to replace your intercooler if you run into an issue and they can recreate it as evidence. I'm in Michigan and have only had a handful of rough idles that lasted less than 5 seconds.
cd_booth is offline   Reply With Quote
Old June 8th, 2012, 13:24   #4
TDI_Dan
TDI_Dan's Avatar
Same here. Michigan. A few rough idles. Nothing else from what I can tell.
TDI_Dan is offline   Reply With Quote
Old June 8th, 2012, 14:26   #5
jstampacchia
Fuel Economy: 5.8L/100km Combined
Here in Ontario I was getting engine lock on start up and chocked off intake during driving. This is only a TSB at this point but should be a full recall if VW was really concern about their customers....
jstampacchia is offline   Reply With Quote
Old June 8th, 2012, 20:48   #6
detroitmike
detroitmike's Avatar
Still waiting on mine. Service writer said its being redesigned. I'm not sure he knows what the hell he's talking about most of the time. If I don't get it, here are my options. Spend a couple grand removing the superfluous emissions components causing the problem, along with a tune of course. Or, take a couple grand hit when I trade this in for a Passat this December.
Sent from my DROID BIONIC using Tapatalk
Power Service Diesel Fuel Supplement every tank
detroitmike is offline   Reply With Quote
Old June 8th, 2012, 22:48   #7
Savageman69
Savageman69's Avatar
go the tune and exhaust route....more power, better mpg....I have the intercooler kit already in mine and its been working great but soon exhaust and chip will take away any fears and worrys and get rid of the stupid random stumbles hopefully
2012 Highline Touareg v6 TDI - 8spd - Silver - Weathertechs - Buzzken Downpipe/Dpf/Scr Pipes - Hybrid 2260 - 4 Bar Map - JR Auto Performance/Buzzken Stage 3 Tune - 31 BFG k02s - Cayenne Trans Coding - Gutted/Painted Muffler - Full Led Swap - EGR Cooler Delete
Savageman69 is offline   Reply With Quote
Old June 11th, 2012, 07:51   #8
Organdonor
Organdonor's Avatar
When it was ordered back in January I fibbed to the service girl... told her I'd had some rough starts, which I hadn't. When I picked up the car she said the tech had found a small amount of water in the lower hose, and even though they didn't think it was that much of an issue they would order the kit for me anyway.
From reading on here it seems as though it depends on your service dept, and how lazy they are. It costs them nothing, and gets them work to bill to VW, so they should be fine doing it.
Old June 17th, 2012, 19:30   #9
nukemech
Fuel Economy: 61mpg iimperial
Default 2010 Jetta intercooler mod kit
My mod kit took the dealer over 3 months to obtain while I drove a rental at their expense as it had turned into safety issue- car on hiway would not go over 30 KPh or 20 mph with foot on floor. Issue cleared after 5 minutes on side of road - engine would not rev above 1600 rpm. Drove 2 hrs home and then straight to dealer.
Told dealer did not want it back unless throughly tested for internal damage- VW tech support told dealer to compression test- passed .
Less than 3 weeks later threw CEL- #3 cylinder counterbalance- VW tech support- told dealer to replace #3 connecting rod. The dealer has been good with me - you have to remember they are go between customer and manufacturer
I wanted new engine from VW Canada and an extended warranty - no new engine but did get 72 month 160k extended warranty.
I gave VW Canada a chance to cut their losses up front with new engine,as I have seen it in the nuclear industry - repair, repair, and then you end up putting the new one in that you should have done the first time- but VW Canada did not take my offer- we will see!
nukemech is offline   Reply With Quote
Old June 17th, 2012, 21:10   #10
CDN TDI
CDN TDI's Avatar
Originally Posted by nukemech View Post
My mod kit took the dealer over 3 months to obtain...
Is there any difference between your kit and the ones that were installed last winter? There's been some talk of the kit being redesigned.
CDN TDI is offline   Reply With Quote
Apparent intercooler icing issue (x2), dealer no help. Whats the suggestions? DZL_Damon VW MKV-A5 Golf/Jettas 50 November 2nd, 2014 18:36
intercooler icing on the A3? palewhitemale Audi A3 14 February 22nd, 2013 18:33
Best way to prevent intercooler from icing? tbone1989 TDI 101 36 February 15th, 2013 15:52
Intercooler Icing / Water buildup NickBeek VW MKVI-A6 Jetta Sedan (~ 2011+) 10 March 15th, 2012 22:55
MAF backorder boingolover VW MKV-A5 Golf/Jettas 9 January 30th, 2010 09:39
Page generated in 0.15624 seconds with 11 queries
[Output: 97.65 Kb. compressed to 83.13 Kb. by saving 14.51 Kb. (14.86%)]
