Old November 21st, 2009, 15:34   #1
s4phillips
s4phillips's Avatar
Location: Live in d/FW, TX. Transplanted from the Pacific Northwet
Default Recap: 12 Months and 39,000 miles on a used Passat wagon
Purchased a used B5.5 wagon late Nov 2008 with 93,000 miles, here is a summary of repairs and maintenance over the last 12-months and 39,000 miles later.
Maintenance and repairs:
CV boot, LH (done day before it was picked up)
Balance shaft module
Timing belt, tensioner, roller, water pump, serpentine belts*
Air filter
Fuel Filter
CV Boot, RH
CV joint & boot, LH (look at line 1 and take a guess)
Oil and filter change, qty 4
A/C 384 relay
Alternator pulley
Wiper blades, 1 set
Glow plugs, qty 4
ECU re-program (because of glow plugs)
Tires, 1 set
Air Lift add-on air adjustable load assist
*The timing belt only had 15,000 miles on it, but I was there and already had all the new parts so it all was replaced.
Waiting for me in the garage…
Transmission filter and fluid change
My opinion: considering this was a used car with quite a few miles already accumulated, and since the purchase has been used like a light-duty cargo van for many of the miles, this car has required very reasonable maintenance and repairs. ...outside of the BSM.
Very happy with this car. ...[picture me] knocking on wood
Future wish list:
Rear sway bar
Shocks and struts
So, just how do you put 39,000 miles on the car in 12-months? Just take a couple of short road trips...
Road Trips to...
Portland OR - Seattle, WA
Tampa, FL
Branson, MO
Kerrville, TX
Wichita, KS
Bettendorf, IA
Ellensburg, WA – Roseburg, OR – Create, NE - Madison, WI
Portland, OR
Kerrville, TX
Dayton, OH
Conclusion after 12-months: This thing has been a great car.
original post: http://forums.tdiclub.com/showthread.php?t=231472
Perform scheduled maintenance; drive more, worry less; balance shaft module; drive more, worry less; torque converter; drive more, worry less...
2005 Passat Wagon TDI w/gear driven buzz reducer and lubricant circulator
2002 Beetle TDI
2003 DL1000K3
s4phillips is offline   Reply With Quote
Old November 21st, 2009, 15:56   #2
MOGolf
MOGolf's Avatar
I hope it is just an oversight, at this posting, that you forgot to list cabin air filter(s).
Unchained motoring
MOGolf is offline   Reply With Quote
Old November 21st, 2009, 16:03   #3
s4phillips
s4phillips's Avatar
...also sitting in the garage waiting for me. ...in the box with a new LH taillight assembly - don't ask.
2002 Beetle TDI
2003 DL1000K3
Old November 21st, 2009, 18:36   #4
deming
Fuel Economy: 38-44
Glad to see one of your trips was to Bettendorf, Iowa.
I was raised just 40 minutes outside the Quad Cities on our family farm.
Let me kow the next time you are in town and we will take you to Whiteys for a Pumpkin shake or Franks for pizza.
Deming
deming is offline   Reply With Quote
Old November 22nd, 2009, 18:13   #5
s4phillips
s4phillips's Avatar
Deming - thanks for the invite. The trip to Q-Cities is a trip the better half does each year without me. I get to hear how good the ice cream from Whiteys is every year. She rubs it in since it is one of my vices.
2002 Beetle TDI
2003 DL1000K3
Page generated in 0.14260 seconds with 10 queries
[Output: 70.10 Kb. compressed to 61.81 Kb. by saving 8.28 Kb. (11.82%)]
