fairbanks
- Joined
- Mar 8, 2013
- Location
- Midlothian, Il.
- TDI
- ‘14 Passat TDI SEL ‘14 Jetta Sport Wagon ‘14 Passat TDI SEL
Original problem 0299 code
New:
N75, vacuum reservoir, fuel/vacuum pump, turbo, cylinder head, timing belt, water pump, vacuum hoses, glow plugs and throttle body valve (twice).
VW said the china version has a hole in diaphragm?
Car starts right up, but the emissions workshop light was still present. Test drive shows no power.
I have obdeleven, this device did not remove the code. I used a cheaper plug in to remove that code. Test drive shows power restored for 2 minutes, The 0299 code reappears?
I drove to work 26miles with the code tool plugged in when it lost power I erased code, cars power restored for a minute, repeat erase?
What is wrong?
New:
What is wrong?
