Recently got a used PD150 installed installed in my car (the PD150 had about 56K miles on it)
. The PD150 never did work right since it got installed. It drives OK if you are a grandma but the moment you step on it, it start to studder and hesitates.. the higher RMP's the more it studders.... like it's missing fuel. This only happens when I try too accelerate hard... (it never does accelerate hard... a frickin prius coud beat me ). It accelerates super slowly and when it gets to high RMP's is misses like it's stalling but does not stall.. just kindda studders with interrupted acceleration .. coasts and misses ... super annoying. It has no studdering issues at all when driving it like a grandma.. it coast fine at lower RMP and accelerates slowly fine until I get to higher RPM's then studders.
The lift pump does make noise when I turn on the key for a second or two but I am not clear if it is pumping like it should.
I never had any issues starting it. It starts super well.... instantly the moment I turn the key..
I just replaced the fuel filter just in case and it did not make any changes whatsoever.... still fubar.. I have about 40K on the lift pump so I just bought another one as a my next step in the diagnostic process. It should get here by the weekend. I will put that new lift pump in and see if it makes any difference.
Also I got an (apparently) super aggressive tune and was told by my tuner that my car should smoke like a freight train with my latest tune... I cannot even see any haze back there.. (My ALH w/ RC6 and Race 520's used to smoke out the neighborhood when I stepped on it)
Could this be a Lift Pump issues? slowly failing lift pump? a lift pump which makes noise but does not pump right?
Also there are currently no CEL. I had an intermittent CEL for CTS so I ordered one of those as well. That one comes and goes but it goes a long time without reappearing.
Also the tune is MAF delete so no issues there.
Any other issues I should consider?
Tandem pump issue? no leaks there, only has 56K on it?
If the lift pump does not work in resolving the issue, I am considering next:
1- changing out the tandem pump - if that does not fix the issue then:
2- remove the injectors & changing replacing the nozzles, maybe even upgrade at the same time. if that does not work then:
3- pour about 5 gallons of gasoline inside and on top of it and burn the MOFO thing to the ground
All thought welcome.... Tnx for your help
